This may be a dumb question but does the brake saver have a plug to drain as well when changing oil. Or just the main plug on the pan.
We have two B models with Brakesavers, and we drain the retarder as well as the pan. As @techmech said it probably isn't necessary, but you will get another gallon maybe out of the retarder. If you really want to get carried away you can drain the two little plugs to drain the tubes going to the pan.
