Well, I finally hooked up the check engine/warning lights. Now they seem to be working fine, however I have a couple questions.
I have acess to a code reader but it takes a day or two to borrow it. I am wondering if there is any way to pull/read the codes from a "E" model using the check/warning lamps? If so, is the a code list posted somewhere?
The last thing which seems odd to me is the check/warning lamps both light when the key is on/engine not running. Once engine is started the check/warning lamps go out, the check light goes out imediatly upon startup, the warning lamps goes out once oil pressure is above 30 psi. At an idle neither lamp is lit. At a high idle neither lamp is lit. When driving down the road however the check light flickers. It doesn't flash on and off as if it is throwing a code, it seems to flicker as if there is a bad connection in the wiring and you are driving on a really rough road.
Any thoughts?
Temp seems to run 195-200* and oil pressure when pulling holds 51-53 psi, cruising it is 56-57 psi. Cold it is 58-60 psi. I know that these run less oil pressure than an old "B" model but should it run that low?
Any thoughts?
