Super *********
I have the 310 and found it to be too smokey to be a daily driver. I run the 275 and have for the past 100,000
Can someone tell me if the 350 is more or less SMOKE?
Thx
Green Goose No Juice
From what ive seen, the two higher tunes than the 310 seem to clean up better than the 310 once the turbos start up..
Reactions: smurfz
Super *********
Well I have a cracked Flex pipe so my turbos take forever to spool. My truck smokes like a freight train!!!
Super *********
Dealer quoted $ 3000.00 to fix? Cab off for sure. I am living with the smoke for now! Not sure which pipe it is as I can't see
Sup smurfz,
My passenger side flex pipe developed a small hole last spring and it doesn't 100% require the cab to come off to fix it. Mine went at approx 26k and they have two options to fix it, cab off or drop the tranny and for me they picked dropping the tranny because it was cheaper. Do a search for my name on the Spartan forums and you'll find my post with all the part numbers and costs.
If I remember right the total cost to fix it was about $700 so just make plans for a trip to FL and have it fixed along the way :).
Gerry
