1 - 10 of 10 Posts
i want to swap my 5 spd for a auto what do i need to swap everything its a 96 f250
What are you doing with the 5 spd and pedals. is there anything wrong with it. I have an auto and want to switch to a 5 spd
thanks andy
trick76cj5 said:
I know Brian from BTS does that kind of stuff, may wanna give him a call. . .pick up a tranny while youre at it:sly:
And a large loan LOL. Yes, BTS may still do that. I think he was looking for the parts list. Maybe the other guy is close enough? Best way would be side by side.
Best way to do it would be to run to a junk yard (or even a use car lot) and take a look at what is there. You will need the pedal assembly (or you can just cut the clutch pedal off and use the pedal assembly that's in there to save money), there is a wiring harness that connects into the tranny so you'll have to see if your wiring harness has provision for that extension. . .you may need a reflash or a new computer, flex plate, i'm not sure if the 5spd uses the same spacer plate between the engine and bellhousing as the automatic you'll have to check into that, you'll need an automatic column or convert to a floor style shifter to select gears. That will give you a start, but looking at your 5spd side by side w/an auto is the best way to determine your needs.
thanks andy
nothing wrong with the trans or anything else just would rather have a auto so my wife would drive it ha ha i looked for a auto truck when i got this one it was just a good deal and figured i would just swap trans later
im with andy ill trade u mine for urs and install both my tranny has6,000 miles on it fresh built tranny with HD parts
will this trans controller work so i dont have to swap wiring or computer http://www.mass-air.com/Products.htm#Transmission%20Controller (its almost to the bottom of the page) then i guess i need steering column for auto and trans 4r100 or e4od which do you reccommend it will be rebuilt to handle some power
It says it's a stand alone control. If it does as said ---yes.
I don't like electronics only transmission control if it's pressure only control. Shift kits and valve bodys send the pressure where and when it's needed and extend life. Some chips like DP will work with Vb's and shifts kits.
where are you located i have an auto 97 my trans is bad but ill switch you the parts and even pay you for the trans and stuff
1 - 10 of 10 Posts
