In the passing lane
ok I got a 6.0 trans cooler for 40 bucks. How hard is it to install? We else do I need to do the install?
beware the dark side
not to hard will bolt right into the same location as the cooler already on your truck. only need to modify the hoses into and out of the cooler and attach them to your trans lines. I just used rubber hose and some high pressure hose clamps.
You can't. But...being the nice guy I am...I'll take it off your hands for $50 :thumbsup
Should be pretty straight forward and mount in your existing location.
TwinStacks
If I recall right my hoses were diff sizes so I had a coupling with the size barbed fittings I needed screwed in on either side and then clamped them tight. Other than that bolts right up.
It helps a lot, you got a good deal.
TwinStacks
:haha yup, thats funny
In the passing lane
thanks for the info guys but Dave you crazy you said you would give $300 for it :haha
your welcome kip for that cooler by the way. im on my way out right now to try and install mine.
I do have one already...just need to find the time to get it installed and get my factory and V10 cooler out.
i finally got mine installed yesterday. i originally used heater hose but decide i didn't wanna risk them not being strong enough so i replaced it with some better stuff.
