41 - 60 of 109 Posts
New post
For some reason my post in introductions shows there, but my post count is still zero, so I will try here.:shrug:
That Was Easy
Thanks
Ok, so the 6mm wrench size was very helpful. Whew, one down and one to go.
Can anyone tell me what size socket to get the housing cover off? I think it's either 34mm or 1 7/16 but in a quick search in tool depts I couldnt find anything like that.
Any hints would be greatly appreciated.
thanks!!
trick to not getting wet while changing filter use a long half inch extension and run it along the fuel rail remove cap and let drain
what's egt mean ??
darsey715 said:
**every 30 days** as told by my diesel tech/friend.
that is a bit excessive. i get my fuel from a quality truck stop, and i've never had to drain mine in over a year. i did it once about 2 months ago just to do it, to see what the big deal was about, but it wasnt even necessary.
as a matter of fact, i'll never have to do it again though since i'm now running FASS instead of the factory setup :)
what's egt mean ??
do you mean frame rail ??
