I have finally gotten my cooler upgrade done :thumbsup
All went very well mounts right in with a brass adaptor everything hooks up perfectly :thumbsup
After idling and half hour drive trans fluid lines still cool enough to touch :D
worked out well and costs all of $45 to do and takes 1 hour with fluid n filter change :happymugs HD COOLER :happymugs
Mike
PHOTOS:
Now after a few days of driving it transmission seems to shift a bit firmer and is more responsive. :thumbsup
So i'm going to have say this project was a successful Upgrade :thumbsup
:happymugs load it Heavy & Run it Hard :happymugs
Mike
after driving to work i parked my truck as normal about 10-20min after parking i desided to touch my cooling line the trans cooler was luke warm at best ! and my engine oil cooler was still flipping Hot ! I think them OEM oil coolers cool the transmission way better then they cool the engine oil. . .May have to find an engine oil cooler upgrade no room to go bigger maybe get the large cooler with the fan ? LOL
Mike
Gone Fishin...
Looking good Mike. Job well done!
Reactions: M123KT-450
My transmission may just out live the engine . . .
Tho for me that would be a GM normality . . .
For me:
1. GM has the weak engines. blow up or wear out. Continuous Alt failures :bang :haha
2. Ford has the weak transmissions n rear ends. auto trans failures or rear end strips yoke intermittent alt failures :bang.
3. Dodge has the weak chassie/suspension n electrical systems. :thumbsup Tho i haven't had 1 alternator failure :thumbsup :bang plenty of Ignition failures tho :bang
Mike
Pardue the Traveler
The Duramax is a good motor, so that throws a monkey wrench into your statement about gm's.:haha:happymugs
The only 2 GM engines i have had issues with is the 350SB (blew up 7 of them) and the 6.5 Turbo Diesel ( repeated brake downs lack of power) .
Tho i did have 2.5L I-4 fail on me but it had 215K miles on it . . .
Mike
Pardue the Traveler
my dad took two 350 tbi's out in his last truck, two transmissions and a rear end as well.
Normally a 350 chevy don't last me but 1 summer.
Mid fall it'll spin bearings and stab a whole in the block and oil pan with bits n pieces of the rotating assembly, the lower end's just don't seem to hold up well. . .
I'm not really a fan of the 350 chevy the 302 ford or the 318 dodge, i have had routine and repeated failures with all 3 of them. . .
Mike
