Banned
!) How many head bolts per cylinder does the cummins 6.7L have.
2) How often does it go into regen?
3) How good are the 68RFE trannies with these trucks?
4) 3500 4x4 SINGLE REAR WHEEL Tow Rating & Payload Capacity
5) Is there a turbo boost gauge from the factory?
6) Do the heavy duties come with trailer sway control.
Anything I should know about the 6.7? Is there a way to have a high idle switch?
1.) The same as any 5.9.
2.) As needed.
3.) Yes, but anything can be broken.
4.) The numbers are inside the drivers side door.
5.) I think that started this year.
6.) If it is not a factory option then the dealer will install.
Why would you want a high idle switch?
ADMIN/MAFIA
26 Total
Depends on how its driven
I like mine. Depends on how its treated what kind of tune etc.. It can fail just ask Eazydeezy
Towing Spec
Not on the pre 2010s not sure if it has been added... Did you not test drive a 2010?
They have a rear sway bar... I tow and can't say there is much sway.
High idle is a factory option just make sure it is enabled by the dealer with the StarScan. You use you cruise control to turn it on or off. And you can raise and lower the RPM..
Don't idle it for long periods, don do a lot of stop and go driving, load it up and TOW.. WORK IT.. I also run my exhaust brake almost all the time, on a stock truck I would run it ALL THE Time.
Banned
Thanks, so I guess I have to ask, how many head bolts does the 5.9 have per cylinder?
ADMIN/MAFIA
Banned
Banned
ADMIN/MAFIA
No not really... Drive Pressure seems to be a bigger concern.
