looking into swapping out the hand shaker zf6 in my truck for a 4R100, along with needing a new pcm for an auto truck and the gear shifter, what are some other things i will need? ive looked into swapping in a c6 (no electronics) but i like having overdrive and the aftermarket overdrive for the c6 is pricey
Have you looked into stand alone controllers instead of a new pcm and tcm. possibly need new flex plate, tranny coolers, possibly steering cloumb for the shifter.
rock removal technition
auto pcm, wiring harness, column can be modded, cluster indicator, flexplate, spacer, trans spacer, auto pedals, if 4x4 transfer case, possibly drive shafts,
I am going to do the exact opposite with my '00 F550 4x4, i have every thing I need to do it. I would have every thing you need to do your swap. I don't know if the manual steering column will accept an auto shifter. My truck dose not have tilt wheel.
Call me I would be interested it trading your Manual trans related stuff for my automatic stuff.
My trans is built for towing, with a billet max low stall converter, trans go sift kit, HD clutch packs, ect
call me
