I'm working on an 08 Western Star with a 60 series Detroit with EGR and DPF. It is a 06R0998711 engine. It has an active 3719 High Soot Level code. The engine runs for about 2 minutes and then shuts down. Connected to the engine with Detroit software to run a Parked Regeneration but apparently can't get the exhaust temp up high enough and the regen procedure aborts after about 12 minutes and throws a "3711 HIR Regeneration aborted - low exhaust temp" code. The engine then continues to run for about two minutes and then shuts down. It has a new intake throttle valve as the one it came in with was stuck. I looked at the catalyst in it and it is not all broken up and appears ok but had a fair amount of soot. I replaced the DOC inlet and outlet temp sensors along with the DPF outlet sensor and all are reading within 3 degrees of each other when the engine is cold. The exhaust system is good with no leaks. The CAC and intake system tested ok with no leaks. The exhaust temps get up to about 487 degrees when the procedure aborts. I ran the procedure today with an outside air temp of about 25 degrees and had the same results as when I tried last week when it was in the 50's here. The engine has had the ecm replaced within the last year due to a different problem. Anyone ever run into this before and have a solution?
