i will take trades, some stuff im looking for is tonneau cover, train horns, 58v ficm, injector cores, amp power steps for 06 cc 155 cc inj, powermax,im sure theres more stuff i would trade for just not remembering at this moment! Located leesburg ga 31763
2000-7.3 147k miles no injectors,icp sensor, or hpop&ipr. Dont really know whats wrong with it we did a compression test and a valve was stuck open so we didnt finish the test, the other cyl we did test had close to 400 psi while the one with valve stuck was 210. $600 firm + shipping or you can pick up
1997-7.3 49k original miles has everything on it including injectors hpop turbo , the only thing i know about the engine is that it had water and oil mixing and when we took the valve cover off we noticed that a freeze plug was missing so we put a new freeze plug in it. since there was mixing going on i would recommend new rod and main bearings i took one off and its not too bad but i would fix while engine was easy to access! $1500 +shipping
2001-7.3 160k miles has blowby on a few cyl, does not have inj turbo hpop. does have plenums turbo pedestal valve covers and gaskets they are just taken off. 400$
97-7.3 200k compression low on few cyl no inj or turbo $400
2006-6.0 150k(20k since machine work) ran good in my truck until i blew the black onyx head gaskets. The heads have been machined down flat and preassure tested, block was machined and so were pistons to make sure nothing would touch and keep everything in tolerances.crankshaft will come with it but the dowel in the tone wheel is broke. ill send arp studs with it also. along with all the misc pieces that come with the engine minus injectors, hpop, and front cover!$1800
you dont by chance have any stock 7.3 injectors for an 02 model would u? Or might know someone that does?
