Diesel Outlaw
ok my buddy has 100hp injectors, m5 fuel pin, gov spring, and a little tuning i havnt drove it yet but he said compared to his buddys truck it doesnt feel like it has that much power. what can i do as far as tuning to get this thing dialed in?
Do a fuel pressure test.
What you have listed could be more than a stock high milage lift pump can handle.
You need to get a taped banjo bolt. Pull the banjo bolt on the oulet side of the fuel filter. Install the taped banjo bolt and then install a gage.
On a stock lift pump you should see 5 to 7 PSI at idle. If your showing any less than 5 PSI. Throw a new fuel filter on it and see what it does.
Do a test drive and see what the PSI is at WOT.
Postback and let us know what it reads.
Diesel Outlaw
ok ill see when he can get it done i work a lot and dont even have enough time for my truck so ill let him know what to do and get back to you thanks for everything
