i have a 95f250 I'm looking to do a front end swap in my truck. i can get a Dana 50 for 300$ but it needs a pinion gear. i was wondering if it's worth the money or just look for a 60? if a 60 is better to go with what year truck should i get one out of? thanks
pretty sure the 50 would be off a SD, so you will have a diffrent wheel pattern in the front and rear. and im not sure it will bolt right up like a 60 off an OBS.
i belive the ones that are a direct bolt on come from 92-97s,maybe from a 91 but im not sure. i got mine from a 96.
i got a Dana 60 the other day. i don't know what year it is out of but it is a king pin style. my truck has 4.10s and the guy that sold me the axle swore up and down that it had 4.10s but when i got it home i scraped off the tag and it looks like 3.54s??? is there even a such gear? any one can tell me were to look for the year of the axle would be helpful. thanks
find the serial number and look it up on the internet. and yes they had 3.54s
i took the vin from the truck to the dealership and the partsman looked up the ratios before i started the swap. 92-97 d60 direct fit, the older king pins, i believe fro the 80s are as well. i did the ball joint one and other than waiting three weeks for and aftermarket trac bar bracket to work with my lift it was a pretty easy job. a good solid saturday re and re both axles. finished up on a sunday with re-torque and double checkin things. plus clean up of misc crap. i definatly thought the swap was gonna be harder, but with a few jack stands and a good jack, piece of cake
