Levi
I have a 95 f350 7.3 and I have to plug in the block heater before I can start it every morning cold or hot outside. I have changed the glow plugs and the relay and the batteries are good to. It also white smokes a hole lot when it does start but that goes away once you start driving.
MAFIA MEMBER 106
does it crank over a long time? before you start it check the fuel filter housing and see if it is full it sounds like you might be bleading off/air leak. also ck your oil level
Levi
Discussion Starter · #3 ·
Yeah it takes a while to crank but when the block heater is plugged in for about 30-40 min it starts right up. And the oil is good. but tomorrow morning i check to see if there is fuel in the fuel filter housing before i try to start it. thanks
MAFIA MEMBER 106
ok i had an old idi 7.3 that would leak down at night and it would white smoke after it started for a little bit utill you got her going the white smoke is an air leak
Levi
Discussion Starter · #5 ·
i checked the fuel filter housing and it was filled to the top with fuel...
