I've got a 95 Wrangler. After it rains and its been setting like over night when you take off go around a corner there is water that will soak your feet if your not thinking about it. Once it does it once it don't do it till it has set and rained. It above the petals somewhere. Anyone had this problem?
I now drive a Duramax...
Squeeky I've never had that problem with my XJ, but if you drill a couple small holes in your floorboards it should drain out...
The water draining out isn't a problem. Got holes already for that. Just my feet getting wet when I take off.
There's a leak in the soft top or the doors. Fix that, and your problem will go away.
Woody
Well I'm not sure if I was too clear or not. But the water is coming from up under the dash. Above the petals.
