Built Not Bought
Anyone get a a/c code? The other night my truck spit out a P0532 a/c pressure sensor to low. Its been way to to damn cold to have my a/c so that theory is out lol. Help please.
Built Not Bought
Anyone???
Were you running your defroster?? The AC runs when the defroster is on because the AC removes moisture from the air so the windows defrost faster.
Built Not Bought
Ya i was. So what does the code mean anything i can fix it with? Or is it nothing too worry bout?
Could be couple of things:thumbdown: Low freon which means there is a leak in the system, bad sensor, plugged/restricted orfice tube, or .... who knows what. To properly check it out need to have ac guages attached to high and low pressure sides and check pressures. bottom line is to get it checked out. Are you still under warrentee??.... if so should be covered:happymugs
