2011 F-250/F-350/F-450 SD Pickups Preview: Emissions Friendly
The 2011 F-Series Super Duty® will be the cleanest Ford truck diesel ever. It uses Diesel Exhaust Fluid to meet the strict 2010 calendar year diesel emissions requirements. Some key features include:
Diesel Exhaust Fluid (DEF) is injected into the exhaust system, to greatly reduce harmful NOx levels
DEF is a solution of approximately 1/3 high-purity urea in demineralized water that is clear, non-toxic and is safe to handle
DEF tank and fill nozzle are located together with the diesel fuel tank and fill on the driver’s side of vehicle and requires refilling at oil change intervals
If the DEF tank reaches 1000 mile distance to empty level, a instrument cluster warning alerts the driver
DEF will be available from dealerships, major auto parts chains, and gas stations
2011 F-250/F-350/F-450 SD Pickups Preview: Best Powertrain
The 2011 F-Series Super Duty® is poised to widen the gap to the competition with these features:
All-new Ford designed and built 6.7L Power Stroke® Turbo Diesel V8 engine is projected to deliver significantly improved horsepower, torque and fuel efficiency features a class-exclusive(1) Compacted Graphite Iron (CGI) block
To meet stringent 2010 calendar year emissions, the 6.7L Power Stroke Turbo Diesel V8 engine features a Selective Catalytic Reduction (SCR) emissions system by using Diesel Exhaust Fluid (DEF) and a Diesel Particulate Filter (DPF)
All-New Ford-designed and built 6.2L V8 gasoline engine with standard E85 flex fuel capability
All-New Ford-designed and built TorqShift® Heavy Duty 6-speed automatic transmission with SelectShift function has bigger gears and advanced lubrication technology to handle the power of the new engines
(1) Class is full-size pickups over 8500-lbs. GVWR.
2011 F-250/F-350/F-450 SD Pickups Preview: Best Capability
Capability matters to a heavy-duty pickup customer. The 2011 F-Series Super Duty® simply gets more done.
Best in Towing
Class-exclusive(1) Trailer Sway Control integrating standard AdvanceTrac® with RSC® (Roll Stability Control™)
SelectShift function to allow customers to manually select any gear needed
Enhanced Tow/Haul mode with engine exhaust braking on 6.7L Power Stroke® Turbo Diesel equipped models
Class-exclusive(1) 5th-wheel hitch prep package provides customers with the convenience and quality of factory designed and built frame components that can be mated with new 5th-wheel or gooseneck trailer hitch accessories
Hill Assist Feature to hold trailers on steep grades
Projected best-in-class(1) conventional and 5th-wheel towing
(1) Class is full-size pickup trucks over 8500-lbs. GVWR.
Best in Hauling
Projected best-in-class(1) payload capability
Segment-exclusive spray-in bedliner
Best Off-road
Hill Descent Control (SRW)
Available Electronic Locking Rear Differential
New all-terrain tire design
2011 F-250/F-350/F-450 SD Pickups Preview: Built for Durability and Reliability
Most F-Series Super Duty® customers rely on their truck for their livelihood. The 2011
F-Series Super Duty backs up the "Built Ford Tough" heritage with this harsh testing:
All-new, Ford designed and built 6.7L Power Stroke® Turbo Diesel V8 engine
250,000 mile diesel engine dynometer test intervals — that's equal to ten years of service in 6½ months
Extended idling for weeks
Extended maximum speed operation for 30 days
Extreme thermal shock dynamometer evaluation
Deep freeze ignition testing
Real world fleet testing
2011 F-250/F-350/F-450 SD Pickups Preview: Best Productivity
Heavy-Duty pickup customers depend on their vehicle for their livelihood. For many customers, their truck also serves as their office. No other truck in the class offers more innovations to make their work easier(1). That’s why the 2011 F-Series Super Duty® has the features these customers demand.
Ford Work Solutions™
SYNC® with Traffic, Directions and Information functionality
New LCD Productivity Screen
110V/150W power inverter
A new center console with accommodation for 2 laptop computers
Front and rear locking underseat storage with auxiliary power point
Midship fuel tank capacity of 28 gallons
MyKey™
(1) Properly equipped. Class is full-size pickups over 8500-lbs.
2011 F-250/F-350/F-450 SD Pickups Preview: Best Design
The Super Duty® customer demands a complex array of configurations and unique specifications to meet their needs. Because Super Duty is a dedicated platform designed and manufactured for this segment, it can be tailored for virtually any application.
Projected to have the most cab, wheelbase, engine and box configurations
All-new exterior styling with a bold new front end featuring signature Built Ford Tough DNA styling including a prominent hood power dome with clamshell design, a more aggressive grille, and bull-like nostrils
The XL/XLT receives a darker gray interior color based on customer input
Lariat receives unique distressed leather seat inserts in tan and black, as well as coordinated wood-grain appliqués
King Ranch receives a make-over with revised logos and black environment
Built to be safe.
• Available front seat side airbags and Safety Canopy™
• Standard class-exclusive(1) Trailer Sway Control
• AdvanceTrac® with RSC® (Roll Stability Control™) standard on all SRW models
• Traction Control standard on DRW models
• SOS Post Crash Alert System
5th-Wheel/Gooseneck Trailer Hitch Prep
Package Contents Long Box only 172" WB
● Factory-installed with Ford factory warranty coverage
● Innovative frame-mounted crossmember
● “Under-the-bed” mounting to maintain a flat cargo
bed floor
● Convenient 7-pin trailer wiring connector located on
the driver’s-side cargo box wall
● Bed floor is laser cut then primed and painted to
maximize corrosion protection. Trim bezels and
close-out covers are installed to keep debris out of
mounting system when not in use
● Optional ToughBed® spray-in bedliner compatibility
Why the 5th-Wheel/Gooseneck Trailer
Hitch Prep Package Is Important
● Customers no longer need to rely on the aftermarket for
their 5th-wheel/gooseneck trailer hitch
● Package is factory-installed and factory-warranted
– Corrosion protection could be limited with an
aftermarket installation since holes are drilled into
the bed sheet metal and not always painted
● Package is compatible with the Ford Custom Accessory
5th-wheel and gooseneck hitch kits rated at 25,000 lbs.
and with modified Reese® Signature Series hitch kits
● Patented “drop-in” gooseneck hitch ball can be
installed and removed all from inside the bed. No more
reaching into the wheelhouse to lock or unlock the ball
● The hitch prep package and any related Ford Custom
Accessories can be included in the vehicle price
and financing
Key Things to Remember
● Super Duty customers rely on their truck for its capability
and are very knowledgeable about towing hitches and
towing accessories — this package and the towing
accessories are an opportunity for you to provide what
they need right at the dealership
● The hitch prep package may not be compatible with a
customer’s current hitch or accessories, so be sure
to determine if they intend to use their current equipment
Super Duty Ready-to-Tow Features
● New-for-2011 class-exclusive(1) 5th-Wheel/Gooseneck
Hitch Prep Package
● New-for-2011 TorqShift® 6-speed Heavy Duty SelectShift
AutomaticTM transmission that includes enhanced
Tow/Haul mode and Progressive Range Select
● Class-exclusive(1) Trailer Sway Control
● Trailer Brake Controller standard on Pickup and
Chassis Cab
● Standard trailer wiring harness
● Standard “Built Ford Tough” trailer tow packages
closely tied to wheelbase and (SRW and DRW) rear
axle configurations
● Available PowerScopeTM trailer tow mirrors
● Available upfitter switches
2011 Super Duty® Offers New
Class-exclusive(1) 5th-Wheel/
Gooseneck Hitch Prep Package
The all-new 2011 F-Series Super Duty is the
most capable pickup in America,(2) especially
when it comes to towing. The Super Duty
heritage of best-in-class(1) conventional and
5th-wheel/gooseneck towing capabilities
and best-in-class(1) Gross Combination
Weight Rating (GCWR) continues with
the introduction of this class-exclusive(1)
factory-installed package.
(1) Class is full-size trucks over 8500 lbs. GVWR.
(2) Best-in-class payload and towing, GVWR and
GCWR when properly equipped. Class is fullsize
pickups over 8500 lbs. GVWR.
Information based on generally available industry data. At the time of this release,
descriptive and illustrative materials contained herein were believed to be correct.
Ford Motor Company reserves the right to change specifications, equipment or
designs without prior notice and without incurring obligation.
SOUNDS TEMPTING, well maybe not
What I've seen in competitors versions of 'roll stability' is a system that when you panic and over correct ,the steering wheel basically disengages momentarily. It's not even a true steering column anymore. A fly by wire set up. What happens when you coming down Wolcreek pass into the turns and the sensors fail???
Also when the urea tank empties does a dash light come on or because its empty and in direct violation of some new EPA laws, put the engine into limp mode so you can get it to the side of the road....? safely, of course
Just 1 question How can Ford say that their truck is better than anyone elses 2011 when the compation has not built a 2011 yet? just a thought.:usflag
Because it's a Ford! Duh, they're ALWAYS better than the competition!:D
I say screw the new diesel. I'm getting the 6.2L
