Vendor
If you're looking to give your Chevy/GMC front-end a little makeover, the Scorpion Series LED Grille by aFe will be your best bet. Being a direct replacement for your stock grille, this product will fit right in with no modifications required. It is TIG welded and features an attractive tire tread pattern that will turn heads everywhere you go. It features durable, rugged construction, two-stage powder-coated finish, high-intensity CREE LED lighting, and stainless-steel hardware.
Today we are here with new aFe Promotion! This fall, you have an opportunity to save 20% on aFe Scorpion Grills. The offer ends on November 30, 2020. Prices are already reduced.
aFe® - Scorpion Series Tread Design LED Grille
Features:
  • One-Piece Laser-Cut Design
  • Two-Stage Powder-Coated Finish
  • Built-In LED Lighting
  • Stainless-steel hardware is included to provide the best corrosion resistance possible for each application
Includes:
  • 1-Pc main grille
  • Military-grade wiring harness
  • Stainless steel installation hardware
