im running intake, straight pipe, and a edge juice w/ attitude. should i even consider getting an aftermarket inj pump?
numbers:
at idle: 8-10psi
cruising: 4-6psi
under load cruisig: 3-5psi
WOT: 2-3psi
are those normal numbers?
when iw as trailering home to columbia, mo from tulsa on I44 i had a twin axle box trailer behind me, wind picked up had to lay into it constantly, was running 1-2 psi up hills. normal?
You don't need a Injection pump, just a Lift pump. A Holley Blue pump is a good upgrade.
bought and installed a FASS 150gph system today. woot
we could only get the Juice fuel pressure senser towork if we ran the fuel thru both the FASS and the original fuel filter, any recommendations?
new numbers:
idle: 13 psi
under load: 10 psi
WOT:8-9
cruising: 10
