Truck died the other day. turned out it was the fuel heater that went bad, replaced that and now i am gettin air in the fuel. the truck will idle nice after you bleed it out and run fine for about a mile. All the rubber lines going to the fuel bowl got replaced when i did the heater. Tried switching tanks and no diffrent. :shrug:
Thanks in advance for the help
Could the fuel filter lid be cracked? Or the gasket bad?
Discussion Starter · #3 ·
I have tried diffrent filter caps and the same thing happens. I checked the fuel return lines from the head to the fuel regulator and i get sprits of air from each line. So does that mean that i have a bad O ring on 2 diffrent injectors, but its runs it runs good.
MAFIA MEMBER 106
beat the piss out of it for 1/2 hour that worked for mine i mean drive it hard for 1/2 hr
