Hello I was hoping I could get an OASIS report on my 2000 SD PSD. I would greatly appreciate it.
Love the site, so glad I found it.
Many Thanks,
Josh
1FTSW31FXYEB82817
OASIS RESULT:
1FTSW31FXYEB82817
07/22/2006
16:36:07
VEHICLE INFORMATION
VEHICLE DESCRIPTION
2000 F-SERIES BODY STYLE
F-350 CREW CAB 4X4 ENGINE
7.3L TURBO - DI
TRANSMISSION
4R100 4SP (DIESEL) AXLE CODE
ENGINE CALIBRATION
GENERAL WARRANTY INFORMATION
WARRANTY START DATE
01/09/2000 BUILD DATE
12/13/1999 SALE MILEAGE
00013
ARN MESSAGES
BEFORE REPLACING DIESEL HIGH PRESSURE PUMP (-9A543-) SEE TSB 04-04-04
BEFORE REPLACING 7.3L DIESEL TURBO PEDESTALS (-6N639-) SEE TSB 04-20-02
WARNING MESSAGES
NO CAMPAIGN MESSAGE(S) FOUND
EXTENDED COVERAGES
NO ESP INFORMATION AVAILABLE
REPAIR HISTORY
NO REPAIR HISTORY ON VEHICLE
END OF OASIS REPORT FOR 1FTSW31FXYEB82817
Standard Claims List For Model Year 2000
1FTSW31FXYEB82817 T/F7 F T/BC T/CD T/E A1 T/DQ T/DS 13-DEC-1999 09-JAN-2000 174021 USA 0 5B04 050306 F81Z 3B396 CA P31 D8 3
AWS Claim Key: 324644 Trx Code: 1 Labor Hrs: 0.5
Dlr Cd-Sub Cd: 08572 - * Name: GRESHAM FORD Ph: 503-6650101 St:OR Ctry Cd: USA Reg Cd: NA Repr Date:05-JAN-2000 Doc #:086740A
Cust Comments: RUBBER O RING HANGING OUT
Tech Comments: DIAG REPLACED LH FRONT FOUR WHEEL DRIVE HUB DUE TO DAMAGED O RING IN HUB
1FTSW31FXYEB82817 T/F7 F T/BC T/CD T/E A1 T/DQ T/DS 13-DEC-1999 09-JAN-2000 174021 USA 4 5V02 060302 * 2001 * N27 14 10654
AWS Claim Key: 1045413 Trx Code: 2 Labor Hrs: 3.1
Dlr Cd-Sub Cd: 08729 - * Name: BEAVERTON FORD Ph: 503-6441131 St:OR Ctry Cd: USA Reg Cd: NA Repr Date:12-APR-2000 Doc #:012200A
Cust Comments: CLIENT STATES BRAKES PULSATE WHEN APPLIED
Tech Comments: 10663 CODE 14 M OR A TIME PLEASE FOR REMOVEL OF REAR AXLES. ROAD TESTED VEHICLE ON HWY. BRAKES PULSATE. CHECKED ROTOR RUN OUT. LF OUT .004 RF OUTT .006 LR OUT .007 RR OUT .007. RR FRONT CALIPERS. MACHINED BOTH FRONT ROTORS ON VEHICLE. RR BOTH REAR AXLES. RR REAR CALIPERS. MACHINED BOTH REAR ROTORS ON VEHICLE. ROAD TESTED AGAIN. O.K.
1FTSW31FXYEB82817 T/F7 F T/BC T/CD T/E A1 T/DQ T/DS 13-DEC-1999 09-JAN-2000 174021 USA 16 7N02 011103 YC3Z 1523394 AA G07 42 32744
AWS Claim Key: 7716153 Trx Code: E83 Labor Hrs: 0.9
Dlr Cd-Sub Cd: 08578 - * Name: TOM DENCHEL FORD COUNTRY Ph: 503-5673291 St:OR Ctry Cd: USA Reg Cd: NA Repr Date:16-APR-2001 Doc #:02116201
Cust Comments: PASSENGER POWER WINDOW HANGING UP. GOES REAL SLOW WHEN USING FROM DRIVERS SIDE. PASSENGER CONTROL DOES NOT WORK AT ALL
Tech Comments: R&R DOOR PANEL. TEST AND VERIFIED MOTOR INOP. REPLACE MOTOR AND REINSTALL PANEL CHECK OPERATION ALL OK .
1FTSW31FXYEB82817 T/F7 F T/BC T/CD T/E A1 T/DQ T/DS 13-DEC-1999 09-JAN-2000 174021 USA 30 2B01 030701 F7TZ 12K073 A D02 42 58178
AWS Claim Key: 16435147 Trx Code: E72 Labor Hrs: 1.3
Dlr Cd-Sub Cd: 08578 - * Name: TOM DENCHEL FORD COUNTRY Ph: 503-5673291 St:OR Ctry Cd: USA Reg Cd: NA Repr Date:03-JUN-2002 Doc #:02993801
Cust Comments: VEHICLE DIED AT STOP SIGN AND CRANKS BUT WON T START. STARTED ONCE BUT DIED AGAIN
Tech Comments: INSPECT AND VERIFY NO START DIAG SHEET. STEPS 1 9 PINPOINT TEST AND REPLACE CAM POSITION SENSOR CLEAR CODES RETEST. REPROGRAMED PCMTO LATEST LEVEL.
