OASIS RESULT:
1FTSW21P15EB97673
04/12/2007
23:50:26
FCXWS447
VEHICLE INFORMATION
VEHICLE DESCRIPTION
2005 F-SERIES BODY STYLE
F-250 CREW CAB 4X4 ENGINE
6.0L DIESEL DI V8
TRANSMISSION
TORQSHIFT AXLE CODE
3L ENGINE CALIBRATION
NO WARNING MESSAGES FOUND FOR THIS VIN
ARN MESSAGES
BEFORE REPLACING HIGH PRESS. PUMP FOR HARD START OR OIL LEAK, SEE TSB 06-17-06
BEFORE REPLACING 6.0L TURBOCHARGER OR VGT SOLENOID REFER TO 06-23-02
BEFORE REPLACING FUEL INJECTORS FOR COLD ENGINE OPERATION SEE TSB 07-05-04
GENERAL WARRANTY INFORMATION
WARRANTY START DATE
01/25/2005 BUILD DATE
01/14/2005 SALE MILEAGE
00025
NO CAMPAIGN MESSAGE(S) FOUND
EXTENDED COVERAGES
NO ESP INFORMATION AVAILABLE
WARRANTY REPAIR HISTORY
01/02/2007
DEALER: World Ford/Pembroke Pines
WARRANTY CLAIM NUMBER: 208378 ODOMETER: 024812M
LABOR OP
CONDITION CODE
CONDITION DESC
6C3Z 3B396AA LOCKING HUB ASSEMBLY 002 1105AT 41 STICKS/BINDS/GRABS
24814 BINDING HUBS ROAD TEST VERIFY COMPLAINT.BOTH FRONT HUBS NOT ENGAUGING PROPPERLY AT TIMES.REMOVE FRONT WHEE LS AND REPLACE AUTO LOCKING HUBS BOTH SIDES ROAD TEST OK AT THIS TIME.
01/02/2007
LABOR OP
CONDITION CODE
CONDITION DESC
7C3Z 19980GA CONTROL A/C 001 19980A 28 OPEN CIRCUIT
000 MTDIAG
24812 ATC DIAG--WILL NOT SELF TEST-REPLACE SHORTED ATC CONTROL HEAD
01/02/2007
LABOR OP
CONDITION CODE
CONDITION DESC
5C3Z 8213AA ORN ASSY 001 16098A D4 FLAW IN MATERIAL
REPLACED FADED FORD EMBLEM ON FRONT GRILLE
11/29/2006
WARRANTY CLAIM NUMBER: 205451 ODOMETER: 022599M
LABOR OP
CONDITION CODE
CONDITION DESC
3E651 ABSORBER-STEERING SH 000 062214B 42 DOES NOT OPERATE PROPERLY
PERFORMED TSB 062214B ROAD TEST OK AT THIS TIME
11/29/2006
LABOR OP
CONDITION CODE
CONDITION DESC
6C3Z 7823394AA DRIVE ASY-PWR LIFT W 001 MT23394 41 STICKS/BINDS/GRABS
22599 VERIFY CONCERN, REAR SLIDDING WINDOW BINDING, REPLACE REAR CENTER WIN DOW REGULATOR ASSY. RETE ST VERIFY REPAIR
10/06/2006
WARRANTY CLAIM NUMBER: 200656 ODOMETER: 018908M
LABOR OP
CONDITION CODE
CONDITION DESC
5C3Z 6K682DA TURBO CHG-EXH DRIVE 001 9438A 42 DOES NOT OPERATE PROPERLY
000 6005F
000 6005F1
000 6005F1X1
000 6005F2
000 6005F6
000 6005F8
000 6005F9
000 6005F11
000 6005F12
000 6005F13
000 6005F14
000 6005F18
000 6005F19
000 6005F20
000 6005F21
000 6005F22
000 6005F23
000 6005F25
000 6005F33
18908 1 15 2263
10/06/2006
LABOR OP
CONDITION CODE
CONDITION DESC
4C3Z 9P456AF COOLER - EGR 001 6005E 42 DOES NOT OPERATE PROPERLY
6C3Z 6K775A COOLER ASSY 001 6005E2
6C3Z 6C646BA DUCT ASY-ENG CHG AIR 001 6005E3
5C3Z 6006BARM ENGINE ASSY/BARE 001 6005E4
3C3Z 9433AA GASKET SET-MANIFOLD 001 6005E5
VC 7B 006 6005E6
4C2Z 12A690AB WIRING ASY EC SENSOR 001 6005E7
5C3Z 9424AA INTAKE MANIFOLD 001 6005E8
3C3Z 6731AA ELEMENT ASY OIL FILT 001 6007A28
XO 15W40QSD 015 6007A
000 6007AZW
000 6007A34
000 6007E
000 MT6051
000 VERIFY60
18908 ENGINE DIESEL WARRANTY VERIFY NO START SHEET 1 THUR 11 PERFORM MANUAL COMPRESSION TEST FOUND CYL # 3 0 PSI AND CYL 1 -2-4 240-300 PSI REMOVE BO TH CYLINDER HEADS AND FOUND #3 EXHAUST VALVE LODGED INTO PISTON AND BOCK CR ACKED CYL 1-2-4 INBETTED WITH ALUIMU NMUM NEEDS LONG BLOCK PERFORM ONLINE D IAG APPOV AL CODE PAA2S REPLACE FQR LONG BLOCK REPLACE IN TAKE MANIFOLD AND
10/01/2006
WARRANTY CLAIM NUMBER: 200101 ODOMETER: 018610M
LABOR OP
CONDITION CODE
CONDITION DESC
3C3Z 6700BA OIL SEAL CYL FRT COV 001 6700A D8 FAILED GASKET/SEAL
000 6007D
18610 NORMAL OPPERATION AT THIS TIME NORMAL OPPERATION AT THIS TIME
09/18/2006
DEALER: Maroone Ford of Miami
WARRANTY CLAIM NUMBER: 610895 ODOMETER: 018460M
LABOR OP
CONDITION CODE
CONDITION DESC
5C3Z 3A674B PUMP ASY P/STRG 001 3674A 46 BURNED OUT
XL 8 MOTORCRAFT BATTERY 003
FOUND NOISE POWER STEERING PUMP,REPLACED
09/06/2006
WARRANTY CLAIM NUMBER: 609373 ODOMETER: 017881M
LABOR OP
CONDITION CODE
CONDITION DESC
3C3Z 6700BA OIL SEAL CYL FRT COV 001 6007D 42 DOES NOT OPERATE PROPERLY
3C3Z 6C751AA KIT-VLV OIL PRESS RE 001 6700A
OIL LEAK DIAGNOSIS REPLACED OIL SEAL AND REGULATORRAODTEST STILL LEAKING CLE ANED RETEST FOUND FRONT SEAL LEAK R&R,RETEST ROADTEST
08/10/2006
WARRANTY CLAIM NUMBER: 606282 ODOMETER: 016099M
LABOR OP
CONDITION CODE
CONDITION DESC
1521850 KNOB DR LOCKING 000 23943AB 07 IMPROPERLY ADJUSTED/FITS POORLY
000 23943A2
VERIFY CONCERN,R&I LEFT FRONT DOOR PANEL.ADJUST LOCK KNOB,OUT OF POSTION
08/10/2006
LABOR OP
CONDITION CODE
CONDITION DESC
6C3Z26611B69AAC S/BELT R/SEAT RETRAC 001 61168A 69 FROZEN/SEIZED/BINDING
VERIFY CONCERN REPLACED LEFT REAR SEATBELT,BINDING
08/10/2006
LABOR OP
CONDITION CODE
CONDITION DESC
6C3Z 17N808B TOWING HOOK FRT 002 MT17N808 81 TARNISHED/FADED
VERIFY CONCERN REPLACED BOTH FRONT TRAILER HOOKS FADING
08/01/2006
WARRANTY CLAIM NUMBER: 605005 ODOMETER: 015621M
LABOR OP
CONDITION CODE
CONDITION DESC
5C3Z 6F089A ACTUATOR ASSY 001 6005F 42 DOES NOT OPERATE PROPERLY
000 6005F1
000 6005F1X1
000 6005F6
000 6005F8
000 6005F12
000 6005F13
000 6005F18
000 6005F23
000 6005F25
DIESEL DIAGNOSIS P2263,VGT ERRATIC NOT WORKING PROPERLY FAILED TESTS,REPLACE D.
06/06/2006
WARRANTY CLAIM NUMBER: 080142 ODOMETER: 012463M
LABOR OP
CONDITION CODE
CONDITION DESC
5C3Z 9J460A SENSOR ASY EGR PR VL 001 05E15M
PERFORMED RECALL 05E15 REPLACE VALVE REPROGRAM PCM
06/06/2006
LABOR OP
CONDITION CODE
CONDITION DESC
000 59B01A
RRECALL 59B01 PERFORMED ROAD TEST REPROGRAM ALL OK
06/06/2006
LABOR OP
CONDITION CODE
CONDITION DESC
000 05B32B
INSTALLED STICKER AS PER RECALL 05B32
06/06/2006
LABOR OP
CONDITION CODE
CONDITION DESC
5C3Z 6F082AA INSERT (ENG.CHARGE A 001 052203A 42 DOES NOT OPERATE PROPERLY
OSP 001 6007D
6C646 DUCT ASY-ENG CHG AIR 000
VERIFIED CONCERN.PERFORMED LEAK DIAG AND FOUND COLS SIDE CAC HOSE LEAKING.IN STALL REINFORCING RING AS STATED IN TSB 05-22-03A.ROAD TEST TO VERIFY REPAIR ,OK AT THIS TIME.
06/06/2006
LABOR OP
CONDITION CODE
CONDITION DESC
5L1Z 7851884AA SEAL-ROOF PANEL OPEN 001 51916B 42 DOES NOT OPERATE PROPERLY
000 50282B
000 50282B1
VERIFIED REMOVE SUNROOF GLASS AND REPLACE WEATHER STRIP REINSTALL GLASS AND ADJUSTED GLASS
06/06/2006
LABOR OP
CONDITION CODE
CONDITION DESC
28611B09 S/BELT FRT/SEAT RETR 000 MT611B09 07 IMPROPERLY ADJUSTED/FITS POORLY
VERIFIED FOUND DRIVER SEAT BELT TWISTED UNTWIST BELT ALL OK
END OF OASIS REPORT FOR 1FTSW21P15EB97673
