Standard Claims List For Model Year 2000
1FMSU41F6YEA97741 T/L1 F T/WD T/CA T/E A1 T/D8 T/DS 15-OCT-1999 13-NOV-1999 156020 USA 7 2I04 NANANA F81Z 12B533 AC E29 42 5975
AWS Claim Key: 1359270 Trx Code: 2 Labor Hrs: 0.9
Dlr Cd-Sub Cd: 08301 - * Name: MOUNTAIN HOME AUTO RANCH Ph: 208-5873326 St:ID Ctry Cd: USA Reg Cd: NA Repr Date:12-MAY-2000 Doc #:027673A
Cust Comments: W CUSTOMER STATES VEH HAD CHK ENG LIGHT ON
Tech Comments: TEST GLOW PLUG CIRCUIT OK FOUND RELAY INTERMITTANTLY OPEN REPLACE FAILED RELAY OK
1FMSU41F6YEA97741 T/L1 F T/WD T/CA T/E A1 T/D8 T/DS 15-OCT-1999 13-NOV-1999 156020 USA 10 5G04 040105 * 5486 * N59 33 9186
AWS Claim Key: 3009145 Trx Code: 2 Labor Hrs: 1.3
Dlr Cd-Sub Cd: 08301 - * Name: MOUNTAIN HOME AUTO RANCH Ph: 208-5873326 St:ID Ctry Cd: USA Reg Cd: NA Repr Date:02-SEP-2000 Doc #:030020A
Cust Comments: W CUST STATES THAT FRONT SUSPENSION MAKES POPPING NOISE IN LEFT HAND TURNS
Tech Comments: TEST DRIVE CHECK FRONT SUSPENSION AND BUSHINGS FOUND UPPER STABILIZER LINK BOLTS LOOSE TIGHTEN BOLTS ROAD TEST RECHECK OK
1FMSU41F6YEA97741 T/L1 F T/WD T/CA T/E A1 T/D8 T/DS 15-OCT-1999 13-NOV-1999 156020 USA 10 7T88 000615 * NPF * E40 82 9186
AWS Claim Key: 3009146 Trx Code: 2 Labor Hrs: 0.3
Dlr Cd-Sub Cd: 08301 - * Name: MOUNTAIN HOME AUTO RANCH Ph: 208-5873326 St:ID Ctry Cd: USA Reg Cd: NA Repr Date:02-SEP-2000 Doc #:030020B
Cust Comments: W CUST STATES THAT TRIP COMPU DOES NOT WORK ADVISE
Tech Comments: CHECK TRIP COMPUTER OPERATION COULD NOT DUPLICATE NPF
1FMSU41F6YEA97741 T/L1 F T/WD T/CA T/E A1 T/D8 T/DS 15-OCT-1999 13-NOV-1999 156020 USA 10 6J08 0114XX * 7821850 * L17 17 9186
AWS Claim Key: 3009147 Trx Code: 2 Labor Hrs: 0.6
Dlr Cd-Sub Cd: 08301 - * Name: MOUNTAIN HOME AUTO RANCH Ph: 208-5873326 St:ID Ctry Cd: USA Reg Cd: NA Repr Date:02-SEP-2000 Doc #:030020C
Cust Comments: W CUST STATES THAT PASS DOOR(FRONT)WILL NOT UNLOCK ELECTRICALLY WHEN COLD ADVISE
Tech Comments: R&I DOOR PANEL FILE OUT HOLE IN DOOR PANEL WHERE LOCK KNOB GOES THROUGH TO ALLOW MORE CLEARANCE TESTOK
1FMSU41F6YEA97741 T/L1 F T/WD T/CA T/E A1 T/D8 T/DS 15-OCT-1999 13-NOV-1999 156020 USA 17 2H01 030008 F81Z 6C640 CA N12 33 12052
AWS Claim Key: 6790859 Trx Code: E84 Labor Hrs: 0.5
Dlr Cd-Sub Cd: 05114 - * Name: LEWIS FORD LINCOLN MERCURY OF HAYS Ph: 785-6253441 St:KS Ctry Cd: USA Reg Cd: NA Repr Date:09-MAR-2001 Doc #:06638201
Cust Comments: HISSING NOISE
Tech Comments: DIAGNOSIS TURBO HOSE CAME. R&I HOSE AND THROUGRLY CLEANED AND REINSTALLED AND CLAMPED TEST DRIVE OK
1FMSU41F6YEA97741 T/L1 F T/WD T/CA T/E A1 T/D8 T/DS 15-OCT-1999 13-NOV-1999 156020 USA 24 * 170501 * * * * * 17162
AWS Claim Key: 12312134 Trx Code: 01S09 Labor Hrs: 0.2
Dlr Cd-Sub Cd: 06864 - * Name: STEVENS FORD LINCOLN MERCURY Ph: 580-2373040 St:OK Ctry Cd: USA Reg Cd: NA Repr Date:25-OCT-2001 Doc #:05842252
Cust Comments: PERFORM RECALL 01S09
Tech Comments: RECALL 01S09
1FMSU41F6YEA97741 T/L1 F T/WD T/CA T/E A1 T/D8 T/DS 15-OCT-1999 13-NOV-1999 156020 USA 47 5G04 040100 1C3Z 5K483 BB N50 33 30951
AWS Claim Key: 21368398 Trx Code: 0711D Labor Hrs: 0.4
Dlr Cd-Sub Cd: 06864 - * Name: STEVENS FORD LINCOLN MERCURY Ph: 580-2373040 St:OK Ctry Cd: USA Reg Cd: NA Repr Date:28-AUG-2003 Doc #:07573151
Cust Comments: CS THERE IS A POPPING IN THE FRONT END ON THE RIGHT FRONT WHEN MAKING TURNS
Tech Comments: 33 KIT STABILIZER END FRONT REPLACE
1FMSU41F6YEA97741 T/L1 F T/WD T/CA T/E A1 T/D8 T/DS 15-OCT-1999 13-NOV-1999 156020 USA 64 2E06 030008 F81Z 9C387 BA D50 42 46293
AWS Claim Key: 23760959 Trx Code: P05 Labor Hrs: 0.8
Dlr Cd-Sub Cd: 04570 - * Name: BLUEBONNET MOTORS, INC. Ph: 830-6068011 St:TX Ctry Cd: USA Reg Cd: NA Repr Date:17-JAN-2005 Doc #:33116701
Cust Comments: CUSTOMER STATES VEHICLE LEAKING FUEL REPORT
Tech Comments: REPLACED FUEL FILTER ASSEMBLY. IT WAS LEAKING. SHOULD HAVE BEEN ENTERED AS A GOODWILL
