Standard Claims List For Model Year 2008
1FTXW43R28EA57314 T/F7 F T/BC T/DB T/E A1 T/BE T/QL 09-MAR-2007 19-APR-2007 121660 USA 1 5A12 050202 * 1177 * L88 D8 598
AWS Claim Key: 50105 Trx Code: 2 Labor Hrs: 1.5
Dlr Cd-Sub Cd: 01014 - * Name: DALE JARRETT FORD Ph: 704-2838521 St:NC Ctry Cd: USA Reg Cd: NA Repr Date:15-MAY-2007 Doc #:36088901
Cust Comments: C S REAR AXLE LEAKING FLUID AT LEFT WHEELS C A
Tech Comments: VERIFIED CONCERN, REAR AXLE SEAL LEAKING REMOVED WHEELS AND CALIPER AND BRAKE CALIPER BRACKET REMOVED AXLE SHAFT AND HUB ASSEMBLY.R&R AXLE SEAL AND REASSEMBLED WHEEL ASSEMBLY AND TIRES.ROADTESTED AND RETEST FOR LEAKS COMPLETE
1FTXW43R28EA57314 T/F7 F T/BC T/DB T/E A1 T/BE T/QL 09-MAR-2007 19-APR-2007 121660 USA 1 * * * * * * * 598
AWS Claim Key: 50104 Trx Code: 07S49 Labor Hrs: 0.5
Dlr Cd-Sub Cd: 01014 - * Name: DALE JARRETT FORD Ph: 704-2838521 St:NC Ctry Cd: USA Reg Cd: NA Repr Date:15-MAY-2007 Doc #:36088902
Cust Comments: CUSTOMER STATES COMPLETE CAMPAIGN 07S49
Tech Comments: PERFORMED RECALIBRATION
1FTXW43R28EA57314 T/F7 F T/BC T/DB T/E A1 T/BE T/QL 09-MAR-2007 19-APR-2007 121660 USA 19 6E01 * * * * * * 24347
AWS Claim Key: 1838303 Trx Code: 08C01 Labor Hrs: 0.3
Dlr Cd-Sub Cd: 01014 - * Name: DALE JARRETT FORD Ph: 704-2838521 St:NC Ctry Cd: USA Reg Cd: NA Repr Date:15-OCT-2008 Doc #:41960503
Cust Comments: CUSTOMER STATES COMPLETE CAMPAIGN 08C01
Tech Comments: INSPECTED DRIVERS SEAT BACK WELD AND INSTALLED SEAT BACK HOLDING FIXTURE PER 08C01.
1FTXW43R28EA57314 T/F7 F T/BC T/DB T/E A1 T/BE T/QL 09-MAR-2007 19-APR-2007 121660 USA 19 2E03 030008 8C3Z 9A543 B E68 D1 24347
AWS Claim Key: 1850495 Trx Code: S07 Labor Hrs: 11.9
Dlr Cd-Sub Cd: 01014 - * Name: DALE JARRETT FORD Ph: 704-2838521 St:NC Ctry Cd: USA Reg Cd: NA Repr Date:15-OCT-2008 Doc #:41960501
Cust Comments: C S THERE IS A LARGE FUEL LEAK OF THE BACK OF THE ENGINE C A
Tech Comments: PERFORMED FUEL SYSTEM LEAK DIAGNOSIS.REMOVED BODY,EXHAUST Y PIPES AND HP FUEL PUMP HEAT SHIELD TO DIAGNOSE.FOUND FUEL PUMP SUPPLY TUBE,FUEL PUMP RETURN TUBE,AND HP FUEL PUMP FITTING LEAKING.REPLACED HP FUEL PUMP,SUPPLY TUBE,RETURN TUBE,AND ALL NECESSARY GASKETS AND HARDWARE.REINSTALLED BODY PURGED AIR FROM LOW AND HIGH PRESSURE FUEL SYSTEMS.RETEST.
1FTXW43R28EA57314 T/F7 F T/BC T/DB T/E A1 T/BE T/QL 09-MAR-2007 19-APR-2007 121660 USA 19 2G01 * * * * * * 24347
AWS Claim Key: 1838302 Trx Code: 08B07 Labor Hrs: 0.5
Dlr Cd-Sub Cd: 01014 - * Name: DALE JARRETT FORD Ph: 704-2838521 St:NC Ctry Cd: USA Reg Cd: NA Repr Date:15-OCT-2008 Doc #:41960504
Cust Comments: CUSTOMER STATES COMPLETE RECALL 08B07
Tech Comments: REPROGRAMMED PCM,TCM,AND IC PER 08B07.
1FTXW43R28EA57314 T/F7 F T/BC T/DB T/E A1 T/BE T/QL 09-MAR-2007 19-APR-2007 121660 USA 19 1F01 * * * * * * 24347
AWS Claim Key: 1838301 Trx Code: 08B06 Labor Hrs: 0.3
Dlr Cd-Sub Cd: 01014 - * Name: DALE JARRETT FORD Ph: 704-2838521 St:NC Ctry Cd: USA Reg Cd: NA Repr Date:15-OCT-2008 Doc #:41960505
Cust Comments: CUSTOMER STATES COMPLETE CAMPAIGN 08B06
Tech Comments: INSTALLED COOLANT VENTURI TEE PER 08B06.
1FTXW43R28EA57314 T/F7 F T/BC T/DB T/E A1 T/BE T/QL 09-MAR-2007 19-APR-2007 121660 USA 31 2E01 030408 8C3Z 9G805 AA E29 X1 33469
AWS Claim Key: 4749845 Trx Code: S07 Labor Hrs: 8.4
Dlr Cd-Sub Cd: 01376 - * Name: PACIFICO FORD, INC. Ph: 215-4921700 St:pA Ctry Cd: USA Reg Cd: NA Repr Date:02-NOV-2009 Doc #:042594A
Cust Comments: CUST STATES CK ENGINE LIGHT IS ON
Tech Comments: CHECK ENGINE LIGHT ON ( VERFIED ) CHECK DTC P0003 ALSO FUSE # 74 BLOWS AND TRUCK HAS NO RUN. PERFORME TSB 07 26 2 THERE IS A GROUND AT FUSE #74 UNPLUG CONECTOR C1926 PIN # 2 YELLOW WIRE IS SHORT TO GROUND REMOVE TURBO AND PUMP COVER REPLACE UNDER PUMP COVER HARNESS RE CHECK NO SHORT ROAD TEST NO CHECK ENGINE LIGHT RUNS GOOD AT THIS TIME CAUSEL PART 9G805 CODE X1
1FTXW43R28EA57314 T/F7 F T/BC T/DB T/E A1 T/BE T/QL 09-MAR-2007 19-APR-2007 121660 USA 33 3A15 070102 3C3Z 7H141 AA E29 42 35990
AWS Claim Key: 4908312 Trx Code: S07 Labor Hrs: 4.2
Dlr Cd-Sub Cd: 03944 - * Name: SPEEDWAY FORD Ph: 770-2291600 St:GA Ctry Cd: USA Reg Cd: NA Repr Date:07-DEC-2009 Doc #:196755A
Cust Comments: CUST STATES CHECK ENGINE LIGHT IS ON
Tech Comments: VERIFIED CONCERN,RAN OASIS,RETRIEVED DTC'S TFT SENSOR P0713,PERFORMED TSB 09 16 09,REPROGRAM ALL,STILL HAVE P0713,PINPOINT TEST G1 MONITOR PIDS YES G2 NO G3 ELECTRICAL SIGNAL CHECK VOLTAGE 4.9V G4 RESISTANCE NOT IN RANGE G5 CHECK HARNESS FOR OPEN LESS THAN 5 OHMS G6 RESISTANCE GREATER THAN 10,000 OHMS G7 RESIS NOT WITHIN SPECS TEST DROVE ALL PASS AFTER INSTALLING NEW TFT SENSOR,RECHECKED A
1FTXW43R28EA57314 T/F7 F T/BC T/DB T/E A1 T/BE T/QL 09-MAR-2007 19-APR-2007 121660 USA 33 6O07 010205 7C3Z 16C826 AA B66 42 35990
AWS Claim Key: 4899980 Trx Code: E84 Labor Hrs: 0.3
Dlr Cd-Sub Cd: 03944 - * Name: SPEEDWAY FORD Ph: 770-2291600 St:GA Ctry Cd: USA Reg Cd: NA Repr Date:07-DEC-2009 Doc #:196755D
Cust Comments: CUST STATES HOOD WILL NOT STAY OPEN
Tech Comments: VERIFIED CONCERN,INSPECT,HOOD SHOCKS WILL NOT STAY UP,REPLACED HOOD SHOCKS,RECHECKED ALL OK AT THIS TIME.
1FTXW43R28EA57314 T/F7 F T/BC T/DB T/E A1 T/BE T/QL 09-MAR-2007 19-APR-2007 121660 USA 41 2G02 031403 8C3Z 12B591 D D21 42 45998
AWS Claim Key: 6339450 Trx Code: S07 Labor Hrs: 0.7
Dlr Cd-Sub Cd: 00368 - * Name: CITY MOTORS OF CARTERSVILLE, INC. Ph: 770-3825780 St:GA Ctry Cd: USA Reg Cd: NA Repr Date:09-AUG-2010 Doc #:069385A
Cust Comments: SHUTS OFF WHILE DRIVING
Tech Comments: CUSTOMER STATES SHUTS OFF WHILE DRIVING VERIFY CONCERN AND CHECK CODES AND REPLACE EGT SENSOR MIDDLE
