can i get an Oasis Report on my truck, im curious if it says anything before i got it. i bought it with 5600miles on it.
Vin# 1FTNX21P83EC52949
thanks
Fuzzy
OASIS RESULT:
1FTNX21P83EC52949
See bottom of the OASIS result for contact ID
02/01/2006
22:05:07
VEHICLE INFORMATION
VEHICLE DESCRIPTION
2003 F-SERIES BODY STYLE
F-250 SUPER CAB 4X4 ENGINE
6.0L DIESEL DI V8
TRANSMISSION
. AXLE CODE
31 ENGINE CALIBRATION
GENERAL WARRANTY INFORMATION
WARRANTY START DATE
07/31/2003 BUILD DATE
02/27/2003 SALE MILEAGE
00021
ARN MESSAGES
BEFORE REPLACING DIESEL HIGH PRESSURE PUMP (-9A543-) SEE TSB 04-04-04
BEFORE REPLACING 7.3L DIESEL TURBO PEDESTALS (-6N639-) SEE TSB 04-20-02
BEFORE REPLACING MIRROR ASSEMBLY (-17682/17683-), SEE TSB 03-23-02
CUDL MESSAGES
THIS VEHICLE HAS A CLOSED CUDL CONTACT
WARNING MESSAGES
LESS THAN TWO DEALER APPROVED AWA REPAIR VISITS PAID TO DATE
03L12
ENGINE EMISSION CONTROL INFORMATION (EECI) LABEL REPLACEMENT
EXTENDED COVERAGES
0765 - USA 2004 36/36,000 RENTALCARE (WARRANTY REPAIRS ONLY)
STANDARD DEDUCTIBLE: 0 USD
OWNER NAME: JASON NELSON
OPTIONS:
EXPIRATION DATE: 07/31/2006
DISTANCE: 36,000
RENTAL: 28 UP TO 3 DAYS
TOWING: 0 USD
CONTRACT SOLD BY: USA 03604
ESP CONTRACT START DATE: 07/31/2003
REPAIR HISTORY
09/19/2005
DEALER: Rhinebeck Ford, Inc.
WARRANTY CLAIM NUMBER: 055998 ODOMETER: 032537M
LABOR OP
CONDITION CODE
CONDITION DESC
3C3Z 9E527AE NOZZLE ASY-FUEL INJE 001 6005F 42 DOES NOT OPERATE PROPERLY
000 6005F1
000 6005F2
000 6005F6
000 9527AR
INJECTOR.......ROADTETSTED AND VERIFIED CUSTOMER COMPLAINT......ENGINE MISSE S PERFORMED ELECTRONIC ENGINE CONTROL TEST...CODE P0267, CYLINDER #3 INJECTO R LOW. REPLACED # 3 INJECTOR. CLEARED CODES, ROADTESTED TO VERIFY REPAIR. OKAY AT THIS TIME.
07/11/2005
WARRANTY CLAIM NUMBER: 054227 ODOMETER: 029220M
LABOR OP
CONDITION CODE
CONDITION DESC
OSP 003 9838A D8 FAILED GASKET/SEAL
3C3Z 9F838EA SENSR ASY F/I TIMING 001 6007D
ICP............VERIFIED CUSTOMER COMPLAINT OF OIL LEAK. INSTALLED DYE AND R OADTESTED VEHICLE. FOUND DYE AROUND ICP. REMOVED ICP SHIELD AND REPLACED I CP. EXTRA TIME NEEDED TO REPAIR OIL SATURATED ICP CONNECTOR. SPLICED IN REP AIR CONNECTOR. REMOVED REAR CROSSMEMBER AND FRONT DRIVESHAFT TO ACCESS WIRE REPAIR. ROADTESTED TO VERIFY REPAIR, RECHECKED. OKAY AT THIS TIME.
02/07/2005
WARRANTY CLAIM NUMBER: 050355 ODOMETER: 020394M
LABOR OP
CONDITION CODE
CONDITION DESC
RECAL ECC PROCESSOR RECAL 000 041904A 04 SOFTWARE REVISION/FLASH MODULE
RECAL...........VERIFY COMPLAINT. PERFORM TSB 04-19-04. RECALIBRATE PCM.
02/07/2005
LABOR OP
CONDITION CODE
CONDITION DESC
3C3Z 8620DB BELT-W/PUMP FAN&GENE 001 041412A 14 SURFACE ROUGH/UNEVEN
BELT............VERIFY COMPLAINT. REPLACE BELT PER TSB 04-14-12.
1FTNX21P83EC52949 T/F7 T/F T/BD T/BD T/E A1 T/BE T/YB 27-FEB-2003 31-JUL-2003 144031 USA 12 2G05 031405 * RECAL * D13 42 8900
AWS Claim Key: 6595352 Trx Code: 2 Labor Hrs: 0.7
Dlr Cd-Sub Cd: 03043 - * Name: RHINEBECK FORD, INC. Ph: 845-8762046 St:NY Ctry Cd: USA Reg Cd: NA Repr Date:28-JUN-2004 Doc #:0444971
Cust Comments: C/S ROUGH IDLE DEAD PEDAL,
Tech Comments: RECAL............PERFORM SELF TEST.CHECK OASIS.PERFORM SSM 16839. RECALIBRATE PCM.
1FTNX21P83EC52949 T/F7 T/F T/BD T/BD T/E A1 T/BE T/YB 27-FEB-2003 31-JUL-2003 144031 USA 12 2H01 030008 * 6N639 * N22 42 8900
AWS Claim Key: 6595353 Trx Code: 2 Labor Hrs: 1.2
Dlr Cd-Sub Cd: 03043 - * Name: RHINEBECK FORD, INC. Ph: 845-8762046 St:NY Ctry Cd: USA Reg Cd: NA Repr Date:28-JUN-2004 Doc #:0444972
Cust Comments: C/S VIB RUBBING SOUND AT 1600/1800 RPMS
Tech Comments: EXHAUST............VERIFY COMPLAINT.PERFORM TSB 04 09 04 NEUTRALIZE EXHAUST.
1FTNX21P83EC52949 T/F7 T/F T/BD T/BD T/E A1 T/BE T/YB 27-FEB-2003 31-JUL-2003 144031 USA 12 2E05 100106 3C3Z 9B249 AB G29 42 8900
AWS Claim Key: 6595354 Trx Code: 2 Labor Hrs: 0.7
Dlr Cd-Sub Cd: 03043 - * Name: RHINEBECK FORD, INC. Ph: 845-8762046 St:NY Ctry Cd: USA Reg Cd: NA Repr Date:28-JUN-2004 Doc #:0444974
Cust Comments: CUSTOMER STATES WATER IN FUEL LIGHT COMES.REPAIR ORDER ALREADY WRITTEN.
Tech Comments: MANIFOLD...........PERFORM SELF TEST.REPLACE MANIFOLD PER TSB 04 09 02
1FTNX21P83EC52949 T/F7 T/F T/BD T/BD T/E A1 T/BE T/YB 27-FEB-2003 31-JUL-2003 144031 USA 13 * * * * * * * 11470
AWS Claim Key: 7255649 Trx Code: 04S15 Labor Hrs: 0.4
Dlr Cd-Sub Cd: 20657 - * Name: METRO FORD SALES INC Ph: 518-3821010 St:NY Ctry Cd: USA Reg Cd: NA Repr Date:09-AUG-2004 Doc #:46391906
Cust Comments: SAFETY RECALL 04S15: 03MY SUPERDUTY EXCURSIONS 6.0L DIESEL NEGATIVE BATTERY TERMINAL TO ENGINE BLOCK CONNECTION
Tech Comments: 1 REPLACED STUD BOLT
1FTNX21P83EC52949 T/F7 T/F T/BD T/BD T/E A1 T/BE T/YB 27-FEB-2003 31-JUL-2003 144031 USA 16 5G03 050301 2C3Z 3050 AA C50 33 15792
AWS Claim Key: 8342695 Trx Code: E84 Labor Hrs: 7.2
Dlr Cd-Sub Cd: 20609 - * Name: ORANGE MOTOR COMPANY, INC. Ph: 518-4895414 St:NY Ctry Cd: USA Reg Cd: NA Repr Date:04-NOV-2004 Doc #:01853151
Cust Comments: CUSTOMER STATES THERE IS A NOISE IN THE FRONT END
Tech Comments: CASTER, CAMBER, TOE IN CHECK
1FTNX21P83EC52949 T/F7 T/F T/BD T/BD T/E A1 T/BE T/YB 27-FEB-2003 31-JUL-2003 144031 USA 19 2G05 031405 * RECAL * G29 04 20394
AWS Claim Key: 9619494 Trx Code: E84 Labor Hrs: 1
Dlr Cd-Sub Cd: 03043 - * Name: RHINEBECK FORD, INC. Ph: 845-8762046 St:NY Ctry Cd: USA Reg Cd: NA Repr Date:07-FEB-2005 Doc #:05035512
Cust Comments: CUSTOMER STATES WATER IN FUEL LIGHT COMES ON ALOT. (HAS BEEN DRAINED ).
Tech Comments: RECAL...........VERIFY COMPLAINT. PERFORM TSB 04 19 04. RECALIBRATE PCM.
1FTNX21P83EC52949 T/F7 T/F T/BD T/BD T/E A1 T/BE T/YB 27-FEB-2003 31-JUL-2003 144031 USA 19 1G03 030507 3C3Z 8620 DB N11 14 20394
AWS Claim Key: 9619495 Trx Code: E84 Labor Hrs: 1.2
Dlr Cd-Sub Cd: 03043 - * Name: RHINEBECK FORD, INC. Ph: 845-8762046 St:NY Ctry Cd: USA Reg Cd: NA Repr Date:07-FEB-2005 Doc #:0503559
Cust Comments: CUSTOMER STATES BELT/PULLEY SQUEALING AT IDLE.
Tech Comments: BELT............VERIFY COMPLAINT. REPLACE BELT PER TSB 04 14 12.
1FTNX21P83EC52949 T/F7 T/F T/BD T/BD T/E A1 T/BE T/YB 27-FEB-2003 31-JUL-2003 144031 USA 24 2E06 030008 3C3Z 9F838 EA L65 D8 29220
AWS Claim Key: 11348599 Trx Code: E84 Labor Hrs: 1.2
Dlr Cd-Sub Cd: 03043 - * Name: RHINEBECK FORD, INC. Ph: 845-8762046 St:NY Ctry Cd: USA Reg Cd: NA Repr Date:11-JUL-2005 Doc #:0542271
Cust Comments: CUSTOMER STATES HE HAS AN OIL LEAK....LOSES A QUART A WEEK.
Tech Comments: ICP............VERIFIED CUSTOMER COMPLAINT OF OIL LEAK. INSTALLED DYE AND ROADTESTED VEHICLE. FOUND DYE AROUND ICP. REMOVED ICP SHIELD AND REPLACED ICP. EXTRA TIME NEEDED TO REPAIR OIL SATURATED ICP CONNECTOR. SPLICED IN REPAIR CONNECTOR. REMOVED REAR CROSSMEMBER AND FRONT DRIVESHAFT TO ACCESS WIRE REPAIR. ROADTESTED TO VERIFY REPAIR, RECHECKED. OKAY AT THIS TIME.
1FTNX21P83EC52949 T/F7 T/F T/BD T/BD T/E A1 T/BE T/YB 27-FEB-2003 31-JUL-2003 144031 USA 27 2E06 030008 3C3Z 9E527 AE D13 42 32537
AWS Claim Key: 12377122 Trx Code: S07 Labor Hrs: 2.7
Dlr Cd-Sub Cd: 03043 - * Name: RHINEBECK FORD, INC. Ph: 845-8762046 St:NY Ctry Cd: USA Reg Cd: NA Repr Date:19-SEP-2005 Doc #:0559981
Cust Comments: CUSTOMER STATES TRUCK SHAKES AT SPEEDS 50 60MPH AND UNDER 1600 RPM,VEHICLE PUT ON SCAN TOOL SAID CYLINDER 3 INJECTOR COUNT LOW CHECK AND ADVISE
Tech Comments: INJECTOR.......ROADTETSTED AND VERIFIED CUSTOMER COMPLAINT......ENGINE MISSES PERFORMED ELECTRONIC ENGINE CONTROL TEST...CODE P0267, CYLINDER #3 INJECTOR LOW. REPLACED # 3 INJECTOR. CLEARED CODES, ROADTESTED TO VERIFY REPAIR. OKAY AT THIS TIME.
ok thanks
