stroke this
got the brakes workin now she won't start. put new batteries in new starter and starter solenoid on the passanger fender. whats goin on is open the door have power and a loud buzzing from under the dash which is coming from the keyless entry remote module took it apart and theres three circuit boards one of the boards has about 6 relays on it and one is buzzing like crazy. turn the key and loose all power to the cab. and i have to shut the door and reopen it to get power to the cab again. could a keyless entry remote module cause it not to start and loose power like that????????? I'm lost:bang
My guess is a bad ground, check the ground from the cab to the rear of the engine over by the heater box also check the ground cable from the batt to the engine block.
stroke this
Roger will do that first thing in the morning thanks
when you say "won't start" dose this mean no crank?
If so bypass the starter solenoid on the fire wall.
I had a '95 that would not crank, I ended up running a jumper wire from the steering column to the starter solenoid.
