1 - 16 of 16 Posts
Levi
I have a 95 F350 and i have put on a cold air intake, edge programmer, and put a straight pipe on it.. but im looking to get more power and black smoke but im not sure what i should do next.. any ideas?
If you want smoke put a set of injectors an a dp tuner w/ the 140 smoke tune and sit back an hold on!!! Good Luck!
TDG MAFIA #101
:whs
Levi
Discussion Starter · #4 ·
what stage of injectors would you recommend with out doing any other work to the motor? and where is a good place to get them? im gunna get the dp tuner it sounds like it puts the edge to shame.
strokin now cummin later!
yeah ditch the edge. go with a dp tuner. you will be amazed the difference in power and smoke
if you not want to mod the motor any more than i would go with a set of hybrid injectors.
blackclouddiesel.com
itpdiesel.com
wideopenperformance.com
dieselinnovations.com
theres more but thats all i can think of that sells them
Macktruckdriver said:
You want smoke check out the vid in my sig thats with DP-tuner and stock injectors.
You know for some reason I get more smoke out of my 80 econo than I do the 140 smoke file.
Maybe every truck is that different.....
Levi
Discussion Starter · #8 ·
itpdiesel.com
alright thanks for the advice.. defiantly going to do it..
I'm currently running stage 1 injectors with DP Tuner 4 position chip. On the 140 extreme setting I can exlipse the sun. The people behind me might not be happy but that's their problem :)
Levi
Discussion Starter · #10 ·
haha yeah thats what im wanting to do... im going to get the DP tuner first and sell the edge... ill have to save up for the injectors though there not to cheap...
no the injectors are very high. i plan on going with 530 b codes. or bigger if they have some out by then. im going for big power though. with running the hybrids they will work fine with the stock hpop. as others wont.
Levi
Discussion Starter · #12 ·
when you say hybrid injectors is that like stage one injectors? i dont know to much about injectors as you can tell...
Diesel Pro
Thats weird I cant get any smoke on the 80E unless im doin like 55 and stomp on it then its maby a little puff if that even. But on the 140 If I lock my TC in first and role it on I make the car behind me disapear just like that LOL But the unmarked cop car behind him didnt think it was funny the other day on the way home from work. :sorrysign:
Mine came from Rosewood. They are a remanufactured injector. Being a reman, injector it saved me quit a bit of money.
Diesel Pro
Hybrid 530's are like stage 3 IIRC. Someone will correct me. The Hybrids dont use as much oil as other injectors like the stock split shots in the SD's
Stage 1 A codes with a nozzle
Stage 2 stroked A codes with nozzle
Stage 3 hybrids
Stage 4 B codes
All you guys craving black smoke better not post up about sh!tty fuel mileage, cuz it's the number 1 killer of a tank of fuel....
1 - 16 of 16 Posts
