No cooling system in a LD truck will dissapate all engine heat at 100% duty cycle in ALL conditions. Ambient temperature, road speed, airflow through the radiator are all very important variables. Not to mention the condition of the cooling system itself, as well as the transmission's condition (most overheat issues start in the auto transmission) LD trucks are rated to tow under ideal conditions with X% margin for error/extreme conditions. GM might not have allowed enough margin for the extreme condition you threw at it, but 99.999% of owners aren't going to deliberately abuse (the load in question could have certainly been considered abuse, and that's without mentioning how far over the limit you were on the rear hitchTxChristopher said:I am not expecting it to run at 100% forever, but 5 to 6 minutes is far from forever. I take issue with your assessment of cooling systems too, I have run them at 100% and a properly designed system will dissipate 100% of the heat it produces no matter how long it runs at 100%. If not the designers either cut corners or miscalculated.
I didn't get a settlement, they lost in court and were ORDERED to pay. Big difference.
If you had the same results pulling a 5th wheel while grossing 18K or less, I'd say you had a serious beef, but not with the load in the video.
If GM wanted to waste more litigation $$$ they could have certainly appealed the decision (and won, or drug it out long enough to run you off), they let you have $35K just to cut losses. The only thing you won was the battle of persistance; if there was truly a design flaw, lawyers would be flocking to make a class action suit out of it.
