I am trying so see how things wound change from my 2004LLY to a 2011 2500 or 3500 SRW.
I tow nice and almost level using a Superglide hitch and Morryde pin book.
The 2011 box's are a solid 2-3 inches higher than my 2004. I can fix that with the 3" riser kit for my hitch they make just for this purpose.
The bed to ground hight is 2-3 inches higher than my 2004. I can't adjust the pinbox, it is already at it last bolt hole.
I would think that either the 2500 or 3500HD's would squat down a little, if this were true it would help bring the nose of the trailer down some what.
Do you tow with either a 2011 2500 or 3500 SRW? What type of hitch do you use?
Whta is your bed rail clearance when hooked up and what do you get for truck squat?
Thanks so much for the information, it will help me make a good decision.
I have a 2011 LML CC/DRW and I have 6" bedrail clearance with a reese pro. Truck totally stock, here's a couple pics. I would imagine SRW would have the same clearance. You'll see the landing gear is still down, though the truck looks the same with it up or down. It doesn't squat but maybe one inch.
ATTACH]27409[/ATTACH]
