i run a zf6 manual and get 15-18....not to many guys running the 5r110....hows it run with the 64mm and 360s
I really don't plan on it lasting too long, but i'll get all i can out of it. The factory pcm has definitely got me beat so far. I"m still learning though!i think you should get that shifting sorted out or you're going to have a toasted tranny real quick-like. everything i've read leads me to this conclusion:
- tuning is essential for the 5r110 lifespan
- the tranny can live behind medium power levels once tuned well
- no aftermarket tuner can make a 5r110 survive at hi-hp levels as well as the factory pcm can
just my opinion.
I'll take any suggestions ya'll have, As far as the timing goes, Don't you just turn the pump a hair?It almost sounds like the TC is locking when it is shifting to 3rd if it is smoking like that. You definitely can get milage out of it. I got 18-19 with a 215hp 12v with 300's, 0 plate, and a S300. The truck was a 92 ford DRW 4x4 with 4.10's and 305's. Also, what HP rating is your engine? You may need to bump the timing up to help with the extra fuel. The industrial P7100's aren't set up the same as the Dodge P7100's.
its not too bad, what kind of set up are you going to have?i will be in the same boat as strawboss soon, i just have to figure out how to install this crazy PCS controller...
stock? why? better turn it up or its going to be a dog!stock 97 12v in front of a 5r110 in a '03 F-450. electric fans, 3" exhaust and a BHAF
