When I bought this truck the guy said it had Stage 1's. I just replaced the o- rings and now it seems I have some oil leaks around the injectors. Wasn't sure if he lied and the stock oldies are failing. Also I pulled the injector plugs to see if it changed the idle and each one did but this one the idle stayed pretty much the same.
no way to tell except by having the flowed... cause stage 1s are modified stock injectors
I got ya. I'm gonna have the shop run a diagnostic on her then. What should stage 1's be pushing?
everytime i see one of them downpipes i wanna puke! get rid of that thing!
rock removal technition
did he say whos they were,
He never got to test the injectors. The reason the idle didn't change when I unplugged it is cause the #7 & #8 cylinders had 175psi and 100psi compression... Wow. wasn't expecting that. Makes sense why I had so much CCV blowby. Anybody need some 7.3 parts? lol
