Ok, I took some photos of the kit.
Complete Kit
Up-Pipe, Check out the quality of the weld
Even Welded on the inside
Here is the cooler delete. Again, check out the quality of the weld
Here is the cooler delete plate/block off plate.
The Plate has a chamfer around the entire outside edge. The plate is also, threaded. Some people call this feature the difference between doing the delete with the intake manifold on or off. Either way you have to take the manifold off, but some call this the difference.
The underside uses an o-ring so you don't have to worry about replacing a gasket if you ever need to remove the delete.
Again, every edge has a chamfer. Notice the chamfer's are different between the two surfaces. This means that they took the time to measure and spec out each one, instead of just using the same for both because it was easy.
