· Dually Club #3
I have an issue with my 06 dually. The passenger front auto hub has locked up and now my axle seal is leaking :swear. First issue, is there anyway to repair the hub? I pulled it out and it looks like it's pressed together with no way to disassemble it. If that is the case, should I go back to the factory hub, or by a warn hub for both sides. Any recommendation here is appreciated. Also, can I run the truck without the hub installed for about 1500 miles?? I need to make a trip down to LA and buying a new hub will be tight on the budget.
Also has anyone torn into the front axles on an 06 dually? I need to replace the seal and any advice would be great. Thanks in advance.
· Senior Member
When I replaced mine- both seized and one was locked a set of Warn were the same as 1 OEM. I went Warn. Getting out and locking is the only downfall.
Reactions: jdydiesel
· Dually Club #3
Discussion Starter · #3 ·
I can't find Warn hubs for an 06 F-350. Does anyone know if they are made for the 05-07 F-350s?
