I do all my own stunts
I am replacing the spicer main in my truck with a Fuller main (5 speed) twin countershaft. My aux box is still a spicer. What is the trick to attaching the shift tower for the spicer AUX onto the Fuller? Now to prevent confusion, this is the shifter for the aux that bolts alongside the main transmission shift tower. I am using a fuller shift tower on the fuller transmission. What do I need to hang that spicer shifter where it needs to be? An adapter? New holes drilled in the spicer shifter?
Kevin
ATHS member Steel Valley
You can make a bracket to mount your tower onto the side of your mail transmission. That way you can use what ever bolts are on the side of the main box. Or you could sell me yours,as I've been looking for one.
I ended up making something and it worked out fine.
aux. box
If either of these units, completely rebuilt at Western Peterbilt, the Dealership in Seattle will work for you, PM me. Also have all other twinstick components and bell housing.
