When backing my 5iver, the backup lights come on and blind me with the reflection. I looked at the owners manual for the fuse location and found if I remove the fuse for the backup lights it also disconnects the Reverse Sensing System. Is that just the system used to warn the driver their about to hit something while backing up? I'm I disconnecting something I need?
If your bumper has the black dot's on it and you have the reverse system it will not work with the fuse out. But you don't need it with a trailer attached so you should be fine.
just find the power wire coming off you trany and going to your back up lights and cut it and run a switch in the cab that way all you have to do is just turn them off
