My factory sensors have stopped working. They are clean. The dash button that turns them off when desired seems to stay lit all of the time. All sensors are "ticking" when in reverse. I suspect speaker might be bad, but I cannot find it. Anyone know where it is . Any other suggestions?
Cannot find any relevant info by searching.
Thanks much.
From what I have read your on the right track, speaker is likely the issue as symptoms are the same as others have had with a faulty speaker.
The speaker is mounted onto the backup module up under the dash behind the glove box according to info from others.
Speaker may just need contacts cleaned or replaced, but it is available separately.
Harry
CASE CLOSED. The speaker was defective. Getting to it was a bear....but will be much easier in the future with my "after market" modification!
Reactions: harry6.0
