I am in the process of replacing my ball joints and I am running into some trouble. First off, they are a bear to get out from the knuckle, even with the ball joint remover I rented. My new ball joints are not wanting to seat all the way down into there spots on the knuckle. I press them in with the tool, but they only go about 2/3 of the way in. I have even tried adding a little grease to help them in. My impact gun that I am using only puts about 250 psi on the press tool so maybe thats not near enough force on the ball joint tool (c-clamp) It seems like they are slightly binding when they start to seat. Any ideas or tricks? Should I seek a better press with higher psi? Can the knuckles be honed a little to accept the new ball joints? Thanks in advance.
shes smart!
I would look for a better press. I wouldnt think you would want to hone them, it sounds like the tools not puttin enough presser to seat them all the way.
Are you using the loaner from Autozone??? If so it is a real pain with this anyway, no impact will do it, you need at least a 28 inch breaker bar, and a vise helps a lot. I still had to at times use a big deep-well socket and a four pound hammer. Make sure to use a socket that will sit on the base of the ball-joint without hitting the part with the threads. It also is hell if you put the wrong one in first, I forget which order they go though.
you could always try to take it to a shop to get it pressed in the rest of the way. It wouldn't take any time for them and I doubt they would charge much.
MAFIA MEMBER 106
put ur ball joints in the frezer for an hour this will help or take em to the shop 12-15 bucks ea its worth the money IMHO
I recently did mine, It takes ALOT of torque to remove or install them. Use a big breaker bar. It also doesn't hurt to crank the tool down tight and then hit the end with a big hammer. Then, crank it tight again and hit with the BFH again until it comes out or seats in which ever you are doing.
Not sure what kind of press your using, but I have an OTC model. kind of looks like a giant C clamp... that with my bertha of an impact drives them in... Yes some are tight fit.. suggestions of little grease, freezer for 1hr are all possible tries...
Discussion Starter · #8 ·
Thanks for the replies. Yes, I am using an OTC rental c clamp ball joint remover. I will try a couple of the suggestions above and see. If not I will have to take them to a shop and have them pressed in. Thanks again.
