I'm converting from 24 to 12 volt starter on my '79 W900A and replacing the battery cables.
Should I use 1/0 or 2/0 cables from the batteries to the stater?
I'm assuming that 1/0 is ok to set them up in series.
Thanks!
Thank you! I needed some back up on that. The old system only had 1/0to the battery, that just didn't seem right!
A 24 volt system only required the cables to carry 1/2 the amperage load of a 12 volt system so smaller cables work.
