To those that have relocated their batteries, where did you put them and how? whats involved ie is it a kit? if not what parts did you use to do it?
I really like robts setup and i know he had them like that when he had twins and now with the CR swap, i would like to mount mine this way with both on the drivers side hopefully he will chime in
Joey
id prefer to have them both on the drivers side, maybe ill just pm rob, was hoping hed see this thread so we could all have the info
I mounted a third battery on my truck. It is set up with a latching solenoid so I can remove it from the system at any time. When camping we use the third battery and a inverter to supply our electrical needs. When the battery dies I start the truck and push a button to put it back into the system to charge it. If I am to let my truck set for any amount of time I remove the battery from the system and have the ability to jump start my own truck if needed. I used a battery box from a diesel van and had to drill one hole into the frame.
same here w/ a 3rd battery on the frame rail under the pass side rear door.
I used a BLUE SEA latch/relay (wont allow draining of the other batteries or charging
of the 3rd battery unless conditions are PREFECT).
i picked up an e350 van box to mount the 3rd battery in.
there are NO kits for this, its all DIY and it isnt cheap.
w/ the bluesea Magnetic Latch/Solenoid i can over ride the inclusion
of the 3rd battery (aka: jumping myself) from the cab via an included switch)
