Inline Junky!
Any where that's not under the hood. What's better the frame or the bed? I don't wanna give up bed space but I will if I have too.
I don't have any kits but if you or a friend can weld, it may be best to make your own. Weld a bracket that can be bolted to the frame rail and hold a marine style battery box. Then run some battery cable to the starter/engine, and I would also install a quick disconnect in the grille (like you see on tow trucks) so you can still jump start the truck without crawling under it.
Hope that helps some,
Kenny
352-636-0812
