Cummins POWER
Has anyone tried the BD diesel boost builder yet? i was looking at buying one because they are pretty cheap but i wanted to see if anyone else has used one yet and if they like it and what kind of hp gain they are getting from it. thanks
If you don't have any extra fuel in your truck you will not see a major increase by pluging the wastegate, not much over 25lb of boost. Also unless you converted to an hx35 the kit will not fit your hy35 turbo. Bully dog makes the J-hook for your truck and it will work on yours if your determined to put something on your wastegate.
does the j-hook work on 01 6-speeds too?
01 six speed should have an hx35 which would use a boost elbow instead of the j-hook.
