1 - 18 of 18 Posts
whats the best cool air/intake system you have tried on your 7.3 trucks? given you the greatest HP/ torque gains as well as mpg
AFE Stage 2 WITHOUT the proguard...
TDG Mafia Member # 37
:iagree: :whs: Gene :mafia
SLAPS Treasurer
I really like my Tymar intake.
Chris
Hmm, lets see, where do I start?
The best intake for the 7.3L is the AIS.
HP gains are from increased fuel not airflow, more air just keeps the pistons from melting.
90% of mpg can be controlled by your right foot.
The 1st reason for buying an aftermarket intake for the 7.3L should be to rid yourself of the crappy stock housing that lets dirt bypass the filter.
After that, it depends on your plans for the truck, if it's a DD with mild mods the AIS is your #1 choice.
If your planning BIG hp mods then an open air filter like the Tymar/AFE would flow the most air.
Ditto on the Tymar.
everybody swears by the AFE Stage II, but i have the dry filter brute force. I have no complaints with it. hope this helps
AIS with fender sleeve no matter what Joe says...LOL
LOL Too funny...
firehunter...got a link?
also:
anyone have a high ram maniforld kit (either banks highram intake or like an ATS ARC FLOW?) benifits? gains?
also:
On a 7.3? Dont know where you would put it... You need the Y pipe to hit both sides?
The AIS is a ford upgrade, check some of the sponsers ( I think defuser ((SP?)) sells it?)
But I would go with the AFE Stage 2... you cant really outgrow the stage 2... You can the ais...
Here you go with a link for the AIS with fender sleeve
Sponsors...I looked through most of your sites and did not see it anywhere???
Discussion Starter #13
i mean one of these type of things
ATS sells one called the ARC flow
and banks sells this one: http://www.bankspower.com/products.cfm
(scoll down to where it says: Banks Techni cooler intercooler system) see the little red thing?
i think its for air returning from the inter cooler.
Not going to work on the 7.3, they have a Y pipe that splits it after the IC....
The 6.0, 5.9, 6.6 all have a colector after the IC so the "arc flow" and such work for them... THere is not one for the 7.3
Discussion Starter #15
oh, okay, thanks for explaining...anything at all like that for 7.3s or no? eventually going to get a turbonetics intercooler and maybe tbo
Discussion Starter #16
also, was i right that its for the air returning from the Intercooler?
Yes your right. There is no upgrade part like that for the 7.3.... You can do a H2e turbo that has a diferant Y pipe... but otherwise you got what ya got...
There are "high rise" aluminum intake manifolds for the 7.3L but they just even out the flow between the cylinders.
1 - 18 of 18 Posts
