1 - 14 of 14 Posts
Local Cummins nut
Ok I am researching injectors to go in the new engine. From your experiance what is the best injector out? Best performing, coolest, & least smoky. I have heard F1 is the best performing & least smoky. & I have heard people say the same thing about DDP. Has anyone run both? plese give me your experiance. I am wanting to go to a 150-200 hp injector but I live in the tree hugging state of CA or should I just leave my EDM'd 120's in it & call it a day?
how you going to smoke test the truck next year and go through inspection?
Local Cummins nut
Not sure. But I dont think it smokes any more on start up or snaping the throttle now than it did when it was stock.
Local Cummins nut
Think im going to go with Mach 4's for now. Maby Mach 5's but just dont now for sure yet.
Local Cummins nut
Anyone else have any input?
I have not run or seen any mach's yet. I run ddp and they are a very nice injector. They also sponsor a lot of events etc so I stick with the people that support things I do.
I was looking at them. The 65hp ones say 600$ on F1's website. Is that each ??
my 110 ddps cost like 650. I will have these for sale soon. They work great just going twins and bigger
I've had F1's for 3 years now and love them. Clean burning, and good power.
DB
Cummins
honistly dont buy new injectors. save your money its a lot better and easier to just get your injectore bored out. they willl work the same as after market ones.
Where do you go about getting injectors bored out? Is it a special company or will a normal diesel fuel injection place do it?
You can change the Nozzels but you will still need to check, and possibly adjust the pop pressure. A builder can ECM a set to the size you want if your cores are good.
1 - 14 of 14 Posts
