1 - 14 of 14 Posts
Currently Diesel Less :-(
I am looking at buying a used 2003 f-350 4x4 w/102,000 miles on it checks ok on oasis, & is a body fixer that w/have to have the cab removed for repair & wanted to know what all mods i should consider(exhaust, studs tuners & which ones, etc.). My dad & i do some excavating jobs on weekends and evenings so i often tow our small excavating equip. (small dozer, bobcat mini- excavater, case 580B backhoe and etc) combined load weight of around 20 -22,000 lbs. but the truck will also be replacing my '96 so it will have to be reliable & driveable while retaining decent fuel milage. cuz itll be my daily driver also.
thanx in advance for all your suggestions
TDG Mafia Member#67
i have an 03 250 6L...im guessin this ones a 6 also, cuz 03 was an option or that or 7.3. if its a 6L, while the cab is removed def. go ahead and stud it! on my truck i put on an airraid intake, i saved some $$ and just cut off my cut and muffler and put on a 5" tip for 150 alltogether, as for a tuner, sct is pretty much what everybody on here recommends because of the shifting and custom tuning abilities they have. as for mileage towing that much weight i would say you will be from 10-12 mpg and empty i have seen up to 21 but that depends on driving habits, gearing of the truck, tire size, etc.....hope this helps!
Darin
Tadd at Elite wrote me a tune for my SCT called the tow boss program. It has full converter lock up on deceleration, a more aggressive tow/mode, and utilizes the vgt exhaust brake feature. It really helps slow the truck down. Any decent exhaust kit with a cat delete will work well. But definately at least install a pyrometer, especially since you'll be towing alot.
i just wanted to say that this is a 6.0 truck, w/3.73 LS.rear , and standard 265/75 16 tires on the stock ford rims , and to thank u guys for the info
ttt
any more suggestions?
well............ get a single non vgt turbo from Elite... you kill a few birds with one stone... get rid of vgt, better airflow, and can utilize an exhaust brake with the non vgt turbos... they are going to have some kind of turbo tow kit for people not looking for go fast builds but want a reliable stout tow rig...these guys are on the ball....
while the cab is off i would do headstuds and our egr blocker plate would be 2 smart things to do
Hey Robert,
Whats an EGR blocker plate do?
The egr block off plate keeps the exhaust gas from entering the "ehaust gas return" cooler. The cooler utilizes engine coolant to attempt to cool the exhaust gas before it enters the intake. This is one of the primary causes of "puking". This is very common when running hotter tunes and especially while towing heavy loads.
Run the block off plate, or get rid of the "Y" to the cooler completely. Also have whoever writes your tunes turn off the EGR also.
Awesome! Thanks for the info.
SLAPS President
killerbee said:
Large capacity Oil Cooler.
Given the discussions concerning the factory oil cooler, does anyone know where a better one can be found?? And even if there is, would it be one that could be used in place of the factory unit and still get it plumbed in correctly??
Discussion Starter #13
:thanks: id like to thank all u guys for all the info it will definately help w/ my dicisions
I Started A Tread Earlier About Building A 6.0 Tow Rig. I Think The Biggest Problem Is Heat And Puking. So I Figured:
Intake
Bigger Boost Tubes (hot And Cold Side)
Intercooler
Intake Elbow
Exhaust (preferably Str8 Pipe)
Tranny Rebuild
Tougher Rear End
Egr Cooler Block Plate
Sct Tunes (with Egr Bypass)
Headstuds With Gaskets And A Set Of Guages
With The Above Mentioned Mods You Should Be Somewhere In The 450 Horsepower Range And 800 # Ft Of Torque. Just Guessing. Should Have No Problems Towing Anything With That Setup :evil:
1 - 14 of 14 Posts
