99 cummins
Did dodge put a smaller turbo on the cummins in '01? A friend of mine told me this the other day and i wondered if its true. If it is, why? Another question I have is what kind of egt's can i expect if i add 120 hp injectors? The same guy said I wouldnt be able to go to the upper levels of my comp with bigger injectors and keep the egt's managable. I run in level 5 all the time now and never get above 1250. (never sustained) Also, how hard is comp box on the injector pump? Should I stay out of level 5 for normal driving?
The turbo thing is kind of true. In 01 dodge switched to an hy35 on the automatic equipped trucks. The hy is junk in many peoples opinion and comes with a smaller ex. housing, 9 cm Vs. 12cm. It makes for quicker spool up, but results in higher EGT's, and ultimately in higher drive pressures too, especially when pushing higher boost levels.
As for the larger injectors, yes you can go larger, but it will be more smokey, and your egt's will get significantly higher. with 120hp sticks you can expect to see 1500-1600 degrees with ease. However, it shouldn't be that hard to control. Also keep in mind though, that you won't have the air to be producing the power that they are capable of. The hx35 is pretty much tapped out at 32psi boost, it just starts pushing hot air at that point, which doesn't increase power and just causes EGT's to climb even higher. You will also want to upgrade your clutch as well, it won't last very long with sticks added.
As for running the comp on level 5 all the time. Yes it holds the fuel solenoid open farther and for longer, which some people say is a bad thing, but however, what I've heard from reputable sources is, that if it is going to cause any damage, it will usually do it in about 20minutes of running it on stage 5.
If it were me, I would think about what the ultimate goal for the truck is. Also, what injectors were you planning on running? You would gain more from an injector with an enhanced spray pattern Vs. one that just dumps more fuel. If you you plan on doing a turbo in the future, getting the 120hp injectors would probably work for you. If you don't want to get into it that deep, stick to something a bit smaller. Personally I love my Rv275's(bosch 300's) they are an inexpensive injector that adds a bit of power, and gives you better milage (in some instances, mine included) also they don't require a core. With all that said, and how much I like them, I have 200hp injectors getting mailed out, but thats for use with the twins.
99 cummins
thanks for the info, i do plan on upgrading the turbo eventually, but i dont know when. i am also going to upgrade the clutch, i plan on waiting until mine slips, so far ive been lucky. its not the oringinal clutch, but i dont know how much hp it will handle. I'll look into those injectors, i havent really checked them out yet. as for the trucks lifes purpose it's mostly just a big toy, somthing nice to drive when i want to feel big power or show off. but i also pull trailers, and haul whatever needs hauled. im not afraid to use it! thanks again for the info.
CENTRAL IOWA #1
i talked to a guy at tst about the hy 35 vs the hx 35 and he said that the hy is just as good as the hx and you won't se a temp change betwen them he said the hy is really larger than 9cm but the rate it that way because there is a divider in the housing
An undivided turbine housing may flow equal to 0.10AR larger divided housing. Since the 9cm housing is undivided, it does not give up much flow over the divided 12cm. Also the HY35 wastegates all 6 cylinders vs only the back 3 on the HX35.
