What are the pros and cons of biodiesel? I was shopping around for a truck and saw one that was rigged up for it, and it got me thinking. So what are some opinions on biodiesel?
What are you calling set up for BIO?
Bio diesel= has been processed (transvirsification) and can be pumped into your tank and run like #2. newer diesels are rated for a 20% blend of bio 80% #2.
Veggie oil= has only been filtered and is run with out processing. This requires starting on diesel and shutting down on diesel. This can be hard on injection systems if not done right.
Bio Diesel has several good points. one is that it is a great lubricant. And acts as an oxygenator when blended. And can ALL be locally grown and made. :usflag
The only real down point is that on older vehicles, rubber seals don't like it. But this hasn't really been a problem since about 97ish depending on the MFG.
Then it all comes to quality of the fuel you use. I know around here, it is becoming increasingly difficult to get enough oil to process.
If you are getting it at a fuel pump, odds are it is blend.
And California has a minimum of 5% at all pumps. Weather it is marked or not. This will be the wave of the future. And here in AZ most of the truck stops are starting to blend too.
The one that I saw had a completely different system for the bio that used only the injectors of the factory fuel system.
I don't really know a lot about how it works or where to get the bio itself haha.
Sounds like it's a veggie system. Not Biodiesel.
Even tho veggie is bio, there is a big difference.
Those can be good systems. Just run really good filters (this will be the most expensive part).
Would it even be worth it after the filters? I'm not planning on getting that particular truck, but it did get me thinking about it for the truck that I do get.
And where can actual biodiesel be found? Is it just at select gas station pumps, or is there a special place to get it?
If you could get a steady source of free or close to free oil the absolutely.
But to run Bio Diesel, you don't need any modifications.
As for where to by bio diesel, just google fuel suppliers in your area.
I know here in Arizona several of the truck stops sell blends. And a few places like Western Stares Petrolium sells 99% bio( for tax purposes age 1% #2 is needed).
Combat Trucker
You can get a map and directions to stations that sell bio here http://www.biodiesel.org/buyingbiodiesel/retailfuelingsites/ Most engines run perfect on b20 or below. They run alot quieter and bio helps lube the injection pump and can act as a sort of fuel system cleaner. Good for your truck and good for the enviroment.
