Hey guys I am very interested in a blow off valve for my truck, but I cannot seem to find one, I read somewhere that they do not make them for powerstrokes because they do not have a throttle plate, but I have seen a powerstroke with one before. I did some more searching and found this. Is this how expensive they are? And does anyone have experience with these in your diesel? Thanks in advance guys. :Thumbup:
not worth the money with no throttle plate like u mentioned its a waste of money save your stock turbo by getting a wicked wheel, ported ats housing, or bigger exhaust housing:popcorn:
the only reason a blowoff valve exists on any gasoline engine is because at shifts when the throttle valve closes, there is a pressure spike that has to be relieved. With a diesel (not just a powerstroke), the engine's demand for air may reduce at load relief or rpm reduction, but not sharply enough to require any pressure relief in addition to air flowing back out around the turbo and out the intake. now if you're having surge problems, follow 03f3507.3's advice.
save the blowoff valves for turbo'd fart can civics.
paul
Personally I think they sound amazing:sly:, it’s just too cool, a friend of mine apparently dropped the money into, but I was impressed:sofa . Yeah that is way too much money thoughfor basically zero functionality; I was reading up more about them just now and found all the same consensus, ugh:damnit. Oh well hehe
Banks makes a blow off valve for the 99-03 powrstrokes, they dont show it on their website you would have to call them and get the catalog they show it in there.Its called the banks big head wastegate it raises the peak boost, the spring in the stock powerstrokes wastegate is 1LB the banks is 20lbs .They also make a new compressor wheel that eliminates compressor surge and a new housing.http://www.banksdiesel.com
If you go on their website and go into the 99-03 powerstroke section you can see the blow off valve, compressor wheel, and turbo housing thats in the powerpack system.You can buy each of them seperate if you want too.
That is NOT a blow off valve. It is a waste gate actuator. Two completely different things.
There is no need for a blow off valve on your diesel unless you are running huge amounts of boost. Usually just on twin turbo systems. When you back out of the throttle the air tries to go back out the turbo. You can hear this as a huf huf huf hufh sound usually just with open element intakes and when you are hard on it and back out instantly. On a stock turbo running the normal 20-30 psi of boost or maybe a little more it doesn't really hurt it much. However if you are running 60 or 80 psi of boost on a twin turbo set up where the small turbo has a small shaft you can snap the shaft in half. So you need a blow of valve. The one BD makes works great and I know a few guys that run them on their twin turbo cummins. However it's not like one you'd find on a civic wanna be. It has electronic controls that attach to the throttle pedal so that when you back out it activates it and blow off the boost. It has several adjustments on it for how fast you back out and stuff like that as well. Hardly anything you're going to want to mess with just to be a poser to make the sound as you can see they are like $600.
