1 - 20 of 93 Posts
11 Second Truck Club
Everybody wants to roll a good number on the dyno but it is so much more fun to blame the dyno for less than expected results.....
To that end here are some helpful dyno excuses including a few of my very own favorites:
My truck did not run well on this _____________ dyno (insert your favorite dyno here) because:
1. The rollers were slippery
2. The air was bad
3. I forgot to turn on the box
4. I never lit the turbo
5. It's not a load cell dyno
6. It is a load cell dyno
7. I ran the small box because if the turbos had lit the torque would have thrown the earth off of its axis
8. My heads would have come off
9. Somebody swapped a Ford 6.0 in my truck when I was not looking
10. My tranny was slipping
11. I forgot to lock the TC
12. We dynoed it in ______ (first, second, third, fourth, fifth, sixth) gear
13. I did not have a lift pump
14. I forgot to turn on the lift pump
15. I ran out of fuel
16. I drove the Hemi today
17. I ran the small nitrous jets
18. I ran the big nitrous jets
19. My bottle was empty
20. Somebody was using my propane to run the grill for dyno day burgers
21. My intercooler got hot
22. This dyno reads way low. My schwinn 10-speed normally lays down .3 horsepower and all we could get on this pos is .1!
23. The wrong correction factor was used
24. It was raining
25. Somebody put a bannana in my tailpipe
26. The switch was in the _______ position (left, middle, right) by mistake
27. I had way too much timing
28. We did not have a Tech II
29. My bottle pressure was way too low
30. The wastegate was set to light
31. My airfilter was plugged
32. We only installed the new injectors on one side of the engine
33. I have a stock tranny
34. It is not broken in yet
35. I used crystal meth instead of water meth. You reckon I can get my money back from those crack dealers?
36. Add your favorite here!
:poke: :roflmao:
The Big Meanie
37. :poke: It's a Chevy? :shrug:
:roflmao: :roflmao: :roflmao: :roflmao:
38. &@%#)#^$Q Clutch is slipping :pissed:
Us gear grinders shouldn't be left out
Diesel Fume Inhaler
39. John "JPonder" put a Winn Dixie mod on my truck.
40. Someone put gas in my truck instead of Diesel.
41) Too SKEERED to push the pedal down cause it will hurt my MPG!
42) Throttle cables always register 0 HP!
So what does a D'max dyno on a single box or uploader? :shrug: :poke:
Depends on which box or tune but I can cross 500 on a single box.
Figures. :bow: :bow:
The window was wrong for my tuner but it worked on every other tuner.
46. i was Dynoing into the wind.......
Yeah, but Brandon cheats! He has injectors.
Seriously though, I have repeatedly taken the Duramax from a 250HP baseline to mid 470's provided it has agood transmission and the air is decent. Exhaust and a bit more huff from the wastegate helps too...
Discussion Starter #14
Forty over injectors and your Boost Valve = Good Stuff! :smoke:
ATS Diesel Performance
duke1n said:
"35. I used crystal meth instead of water meth. You reckon I can get my money back from those crack dealers?"
This is a common excuse coming from Dockboy. What a crack ho!
:roflmao:
LOL
:agreed:
Diesel Nutbag
:roflmao: :roflmao: LOL LOL
CO boys don't need to worry about having dissapointing numbers!!
They always get that 20% boost!! LOL :poke: :evil:
Diesel Nutbag
duke1n said:
LOL Does steriod use count as a drug 'cus word is my new huffer has some roids in it. 600hp straight up diesel baby, ought to quiet down Dockboy for awhile ;) I don't need no stinkin twins lol
I'll believe it when I see it! :umno: :blah: :roflmao: :popcorn:
You'll be seeing it soon trust me. God forbid I run the thing on a generous Dynojet and not that Superflow lie detector. You're goin down like a red-headed step child. Throw in my extra 20% you mentioned and you'll be so far behind I'll have to pull out the binocs to even see you. Now hows about the DMax guys? Who here is not a crack ho like Dockboy?
1 - 20 of 93 Posts
