1 - 19 of 19 Posts
How much boost should a 2002 7.3 Liter F-350 make with an intake, edge box , superchips programmer, and a straight piped exhaust?
I be Architect'n
Maybe lower to mid 30's, but definitely high 20's w/ no boot leaks or turbo issues.
Smarter people than I will be along shortly.
coreystroke02
I'm making 32 lbs. at WOT, which is a little much. Around 26-28 lbs. is the limit with a stock turbo. If I keep on, I'll be a smoking another factory turbo.
25-30#'s.... Stock turbo is rated for 25#'s but can handle 28-30 for short times without grenading
Running the turbo out of it's compressor map usually means it's over-speeding to start with. Then you are also creating excessive heat and side loading the shaft. The stock turbo has a horrible thrust bearing and doesn't take much abuse for long.
With stock turbo and and Edge/Juice I saw 25 pounds which is where I had my waste gate set. Now with the DP-Tuner and a new turbo I can get more boost than I want to have.
Sorry to side track this tread, but what boost should I see with a stock system? My quadzilla shows me 14 psi if i put the petal to the floor. Is that normal? or should I see more?
Thanks
Its a little low, stock should see about 18
There a bit tougher, 27-30 psi on the OBS stuff seems to be the norm
Well -- I am curious as to mine as well. An early 99 7.3 - how much boost should it be pulling and about what can I take it to before it's going to die?
Same thing, about 18-20 stock. 25+ with a chip. I have seen early 99 turbos take 30psi for lots of miles...
Thanks
If you have the old quad that reads off the stock MAP sensor, you may not be getting an accurate reading. I think they have a new upgrade that puts in an aftermarket MAP for the quad to read- independant of the stock MAP. A buddy had the quad in his truck- I wouldn't trust the boost display.
Cummin' get ya some!
hmm i think i have a leak or something b/c the highest ive ever seen mine was 24 w/ everything listed in my sig.
Try disconnecting your wastegate. Even with my mods listed, I could only hit 23-24, and I had to be on it very hard to hit that. I disconnected the WG and it made a night and day difference. Spool-up is fast and I can readily hit 25 ...touched 30 at one point towing when I wasn't paying attention. That won't happen again. :damnit
Put a hole in my wastegate line and a boost relief valve before the map, i hit 28-30 easy, spool up time is a lot faster.
i used to have my wastegate unplugged before i got the juice w/attitude but i hooked it back up i was a little worried with it surging but i guess i could monitor it now with the attitude on the way home to night i had it on extreme and to the floor i could only get 24.4 but im defininetly goin to unplug the wastegate again
LocoMotion said:
I can peg my 30psi gauge :shrug:
:evil:
:shrug: I can beg my 40#...:poke: LOL Without my oil kit...
1 - 19 of 19 Posts
