1 - 14 of 14 Posts
all its gunna do is keep your CEL light from coming on at higher "overboost" pressures witch in the 7.3 case is around 15psi. Just unplug your wastegate controller then you will get full boost. My CEL comes on even with Codes tunes on my DP tuner, and it doesnt effect anything.
where do you unplug the wastegate controller at?
thanks man
I have the codes tunes on my DP and havn't had a light come on since installed. I wonder what the difference is?
the wastegate controller is directly in front of the turbo. there is a red and green line that run into the controller. there is a 2 wire plug that goes into the controller just unplug it and thats all. with mine plugged in my truck was only slighlty faster than stock. once i unplugged it HOLY CRAP hold on!
TwinStacks
Just order the MAP Maximizer from dfuser or the dual release one. I have the one from TheDieselSite. It stops the MAP sensor from seeing over 17psi of boost.
MAFIA MEMBER 106
no it for 99 up oinly pre 99 didnt have a waste gate put a regulater inline with the map sensor like mine is
see how the line comes in then out to the map sensor and sd's dont defuel untill 22 psi so mine is set at 20 psi no problems
OBS do not defuel like the superdutys do...
i have had my 95 at 29psi and never had it defuel
Smokin'
**** on all of those overpriced mechanical setups.
Buy yourself a 4.7 .5 ohm and solder it into your map sensor lines. It will never see more then 19psi and it cost 1 dollar.
Here is mine.
wastegate controler
can u unplug this on a factory truck ? Will it hurt anything ? I'm looking 2 get a few more hp out of my truck, I upped tire size to 265 70 17 ,s . fuel milage is still about the same but I'd like more boost ..
No you can not unplug your map sensor, your PCM needs that info to fuel properly.
MAFIA MEMBER 106
1 - 14 of 14 Posts
